New Wheel Design
Started by Alexioco, April 16, 2009, 07:52:51 PM
Alexioco
Quote from: Low-Q on April 17, 2009, 06:55:57 AM
Looking forward to see someone who can show that gravity isn't conservative. ;)
lol you will see the best ever non-runner yet  ;) actually i'm kinda of hoping it works  :o
@Alan, ok Alan, I will check the email you sent me, never mind about that other wheel then Alan, its ok, if this new wheel doesnt work, I will have a go at it :)
There is somthing strange about this wheel, if it works, im not sure if it can start itself off because: there is no start or finish to the wheel, so that means, when its still it is wrong, it has to be moving to exercise its spoecial movment, if the wheel is still and started off it will do the wrong movment, so i will have to start it off in a very strange way until i can sort it out lol
I'm 50 - 50 to weather it will work or not, if not then it is possible to improve it by adjusting the weights etc which when I post it on we can have a good look at it either way... if the wheel can start itself off and complete its movment, then its a runner, if it cant and i have to give it a push, then i dont know what the result will be, the weights do indeed lift to keep the wheel going, but its weather there is enough momentum to keep it going, have to see...
Alex
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
tagor
Quote from: AB Hammer on April 17, 2009, 06:35:49 AM
Just think of the guy in France that built one the size of a large Farris wheel.
but this device does not work !
Alexioco
Quote from: overtaker on April 16, 2009, 09:44:33 PM
I am very intrigued!  Do the weights raise to the rim at 12o'clock?   Then gravitate back to the axle?
Most designs want the weight from the rim at 12 o'clock to stay at the rim till 6 o'clock then back to the axle.  I'm so confused but also so excited to hear " the rest of the story ".
Hi overtaker, the weights lift themselves just before 12 o clock and push down to the bottom at 6 oclock then take themselves into the axle... a single weight can do this on its own.
erickdt
Of course gravity is conservative. That however does not mean it isn't capable of producing work.
Alexioco
Hi all, Now I could do with somone telling me where I may get some weights from, weighing 1 - 6 ounces because I need the following weights:
two of 1, 2, 3 ,4 ,5  and 6 ounce weights (for test purposes) 3 ounces with probably be the best but I want to make sure...
Edit: Once I have the weights, then all I need to do is make just one more thing and the wheel is done, I could possibly have it done for monday. Some of you here could probably build my wheel within a day :P
Thanks
Alex
