Does a proven working TPU device exist at this time?
Started by AquariuZ, April 17, 2009, 08:47:22 AM
Grumpy
only gravity deflects it
Quote from: BEP on May 02, 2009, 09:24:48 AM
@Otto
If the problem is common EM fields then a simple Faraday cage will help. Just make sure all seems are good electrical connections and the cage is well Earthed.
Should the problem be the other way put solid mass between you and the TPU. The more solid and thicker the better. Distance helps a bit here, as well.
I don't know what your TPU could be radiating but you should check all possibilities before long. If you awake with white spots in your vision, headaches, nausea, etc. You should stop and fix the problem.
Repeated small EMP can also cause confusion and lethargy. Don't let it go that far.
        -Frank Edwards
BEP
Quote from: Grumpy on May 02, 2009, 10:23:10 AM
Maybe it is a good thing but I can't agree with you until my 'Black Hole In MY Basement' project works  ::)  Maybe CERN will figure this out.
Until then, mass (very dense or lots of it) does a good job.
otto
Hello all,
@BEP
I dont have magnetic fields inside my TPU. The particles spreaded out of the transformers are my problem but as Im now good in my job there are not anymore so much particles leaving the TPU transformers and so my health is much better.
Thanks anyway.
Otto
Phantasm
Quote from: otto on May 02, 2009, 04:54:17 PM
Hello all,
@BEP
Thanks anyway.
Otto
Glad to hear your feeling better! I hope you are having good results and much excitement :)
giantkiller
Quote from: -[marco]- on May 02, 2009, 02:47:52 AM
sì bene se stiamo andando parlare tutte le lingue differenti nello stesso filetto, come il della MACEDONIA CD, quindi voi può essere it' sicuro; s che va essere un grande disordine!
Marcos.
Grazie, grazie, grazie!
faleminderit,
شكرا Ù,,Ùƒ
谢谢æ,¨
tänan
In het geval ik iemand gemist
And
Ank-thay ou-Yay! for those that have swine flu.
--giantkiller.
