Does a proven working TPU device exist at this time?
Started by AquariuZ, April 17, 2009, 08:47:22 AM
Grumpy
Quote from: BEP on May 02, 2009, 03:42:02 PM
Until then, mass (very dense or lots of it) does a good job.
and/or distance...
I expect it will be more well-behaved once the current loop is formed.
        -Frank Edwards
MACEDONIA CD
HI
@GK  falemenderi  is in the <albanian  people  >not macedonia
@marco find how to  write in macedonia but
ok  you are have  short brain to anderstend macedonia languege
  and you show that you dont know to READ  in languege of  tesla main  country where is born
  LEARN  AND MAYBE WHILL KNOW  BETER TO ANDERSTEND WHAT TESLA SAY ;D
ISEE NOW  YOU NEED SOME  SHORT VIDEO  FROM ME   TO SEE AND  LEARN SOME STUFF  @marco
Yucca
Quote from: Grumpy on May 02, 2009, 10:23:10 AM
only gravity deflects it
Yes, it might be very useful and interesting to have a well shielded and filtered scalar detector running on the bench of any TPU experiment.
I think the Hodowanek detector  is the simplest type to build:
http://www.amasci.com/freenrg/grav3.txt
Tito L. Oracion
hi everyone good day!!!
i'm back ;D
i just want you to know that i found something old in my vicinity.
i notice the high tension wire is connected in one pole of the transformer and the other one pole of the transformer is connected into the earth ground  ??? and it gives 220v! wow and unlimited connection of transformer is available in the high tension wire, i think this is one secret of tpu?
i'm telling the truth please observe.
case closed!  8)
God bless otits
Bruce_TPU
Quote from: Tito L. Oracion on May 16, 2009, 06:59:14 AM
i'm back ;D
case closed!  8)
God bless otits
Tito,
Nothing is impossible, it just has not been discovered yet (by some).  If you don't believe that SM did anything but steal power from the lines, then you are wasting your time and everyone else's.
Try reading the engineering reports.  The TPU was/is real.
AT EVERYONE ELSE,
Steven Mark gave every detail of how to build this in the PDF that Lindsay had put together.
The truth is, no one wants to build a working TPU.  They are either too fearful, or have too many of their own ideas in their head and will never have anything that works.  SM was right.  Ego, a freakin' shame.  That's why no one sees.  It is pitiful.
Or because they can't figure it out, it must not be true... HA!  More ego.
If you knew how it works would you build it?  Eh?  No!  You'd watch one or two brave ones build it.  Do I sound cynical?  Sorry, I am disgusted.  The truth?  Most people can't even follow the simplest of directions.  Why?  Because everyone hears what they want to hear.
If mine worked do you think I would post it hear or anywhere else?  HA!  You've gotta be out of your mind.  I would try to lead others to understanding, but that too appears fruitless.  The solution?  Go it alone for now, I reckon.
