Maxinum utilization or Back EMF...?
Started by the_big_m_in_ok, April 19, 2009, 01:30:47 PM
the_big_m_in_ok
the_big_m_in_ok said:
I'll also try and upload my schematic.  On a borrowed computer.    :-\
>>Okay, I tried.  I wrote an explanation of what I was trying to do before I tried to upload my schematic in three attached files, then I scanned the 3 pages with the American software package PaperPort, and the computer locked up when I tried to upload the whole post!
It wouldn't unlock at all, either!
It would Spell Check for me, however.  Really!  A selective computer/software glitch?!
Each page was a typical 8 1/2 " X 11" sheet with lines drawn in pencil on them.  I don't think each whole page would have amounted to 250 KB?
I could also do it in .PDF or possibly WinWord, as an alternative, but the reader would need a software package compatible with that particular format to download the data.
Oh, well, the next best thing I can try is to reference other posts on Overunity to try and describe what I mean and have Members look at other, similar posts to gain insight from them?
Any ideas on dealing with software issues, anyone?
P.S.
This post did actually upload and run, obviously, so the .JPG attachments were the hangups.
--Lee
the_big_m_in_ok
gyulasun
Quote from: the_big_m_in_ok on April 23, 2009, 03:52:23 PM
P.S.
Hi Lee,
Attachments have been limited to max 100kB in filesize until recently, now I am not sure but if you have bigger than 100kB files then you may wish to go the Upload section of this Forum (see it as Upload icon in the upper left column), here is a link for it: http://www.overunity.com/index.php?action=tpmod;dl=upload
You may upload max 5MB files there.  (JPG could not have been a problem but the size as attachment.)
rgds,  Gyula
the_big_m_in_ok
>>Okay, I tried.  ...I could also do it in .PDF or possibly WinWord, as an alternative, but the reader would need a software package compatible with that particular format to download the data. ...Oh, well, the next best thing I can try is to reference other posts on Overunity to try and describe what I mean and have Members look at other, similar posts to gain insight from them?
>>Okay, now I have a reference...
http://www.overunity.com/index.php?topic=7253.0;topicseen
Now, for modifications, I would take some of the voltage through two transformer tiers (100V to 12V to 1.2V) and then re-transform that with back EMF to 110V.
Trythis:             ___
                |||  (___
        ____  |||  (___
   A  ____) |||  (
        |________|      B)
         |___<|__|
                C
'A' is the input of 1.2 V from the second tier of step down transformers.
   (Radio Shack sells a 110VAC-12VAC line transformer with a .45 A secondary.)
'B' is connected to the other side of the primary to step up the voltage like a Tesla coil.
'C' is an optional diode to prevent back EMP power surges from cooking a secondary coil or a transistor oscillator that drives the circuit.
This way, the secondary of the step-up set of transformers act as a counter-wound bifilar coil.
It might be better to use toroids instead?  Caduceus coils?  In series or parallel?
The parallel output(s) can be rectified to a bridge and back-fed to the battery bank in the drawing above.  Or to a capacitor bank and then to the batteries? The latter coils I mentioned should inherently be better for OU functioning.
The possibilities are numerous, if one uses the imagination.
--Lee
--Lee
the_big_m_in_ok
