The Gravity Control Problem
Started by truth, April 19, 2009, 05:41:29 PM
truth
truth
Quote from: P-Motion on April 24, 2009, 12:38:59 PM
  Truth,
  If you look at my 3 weighted design, it uses gravity twice.
                                                             Jim
If you would please, providing a link to it would be helpful!
Thanks    ::)
mr_bojangles
what is this talk of liquid and floating business
surely it would be because the mass of an object being less dense would float, because the pull of gravity would be greater upon the more dense material
maybe figure a way to efficiently make a material more then less dense to create a vertical movement, whereupon making it less dense allowing it to sink again
(i.e. ice floats when cooled, a vessel of water in a pool or larger container of water could be cooled to freeze and become boyant, whereupon the cooling mechanism is halted and vessel is allowed to return to bottom via weights, etc etc)
not necessarily a way to shield gravity as you suggest but maybe an alternative way of harnessing it
might not have been what your looking for but it was my initial response to the topic of viscosity and gravitational effect on liquids
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
truth
OK P,
I looked at that "Three Weight" thing or idea or just plain incomplete post of yours.
It appears that no one has understood what you are suggesting, including me.
It appears to be just another  big round balanced object. I don't see where it uses gravity even once much less twice.
Perhaps you could CLARIFY what you are thinking?
PhiScience
Hi truth,
I wish I could give you the answer today but.
  Electric and magnetic fields differ from the gravitational field in that the flow of ether in electric and magnetic fields is always confined to limited regions.
It ether passes from negative to positive charges, around a closed circuit, whereas in a gravitational field the ether merely passes through any body that is in its path.
That is the reason why all efforts to screen or otherwise control the gravitational field have been unsuccessful.
  The problem, however, is not entirely hopeless.
The very fact that the gravitational field acts more effectively on protons, than upon electrons, seems to show that gravitational ether currents do co-act in some specific manner with electrically charged particles, and when we determine the manner in which they co-act, then we shall be in a better position to solve the problem of Gravity Control.
The function of science is to make observations and measurements and to find correlations between the observed facts.
