Falling chimney enigma...
Started by iacob alex, April 20, 2009, 09:25:52 PM
iacob alex
   ...is a free fall paradox,when a rotational free fall in gravity,causes a faster then  "g" acceleration,as you can see at :   www..physics.brown.edu/physics/demopages/Demo/solids/demos/1q2050.html
      Faster than "g" ?
      Who is the "donor" ?
      Maybe,this universal substratum,including of gravity...the incorporeal,ethereal inertia ,asks some additional work from gravity.
      Regardless of manner to explain,or play words,we have a real,unavoidable fact,just around the corner...
      Can we use this circumstance?
      Maybe,if we remind the Newton's suggestion about PM...
                       All the Bests! / Alex
iacob alex
...can be expressed also ,by a lab-demo "Falling stick..."  at:   www.phy.syr.edu/courses/demos/7e.html
   Usually,the angle between the two boards of the hinged structure is around 40 degrees.
   But,if we try a test with a greater angle(near 170 degrees),maybe we become more inquisitive about a possibility to use this phenomenon.
iacob alex
   .....at :   http://www.tynemouth.frankgillings.com/882.htm   can be a more convincing and impressive proof (if you watch the video...),about an interesting effect...maybe useful for the topic of this forum.
iacob alex
...if you type "falling chimney" on net,you can get a plenty of information.
    The next step can be,to relate the "falling chimney" with an "inverted pendulum"(see on net,also),but not as a pendulum studied in robotics (a limited and controlled swinging),...this time,the pendulum can fall 180* ( a full fall down).
    For a physical pendulum,the center of rotation can be somewhere,so that we have a new (and useful for our topic)  image:a first class lever ,with two unequal arms,free to manifest a full fall down (180*),due to gravity.
    The last step is to play (in some way...),the torque difference on the same side of the pivot.
    Why this topic?
    Simply,because a pendular fall accelerates more than a vertical free fall.
    If we have a difference,it can be a starting point to think about...
       All the best! / Alex
