The ever elusive magnetic motor
Started by billmehess, April 22, 2009, 10:49:31 PM
The Ronin
Bill,
I've been watching your videos with great interest and admire your approach to the problem. I, too, think it's possible for a magnetic motor to work, and after seeing your latest video I think you're on to a possible solution.
I don't know if this would work, but I'm throwing it out there to see if it helps.
Surely the easiest way to re-engage the stator is to lengthen the housing the 'stator block' is put into and fit a wooden shelf to the bottom. Make the housing deep enough so the stator block doesn't repel the top magnets in it's magnetic gate when it sits on the shelf, but obviously doesn't come down so low as to hit the bottom 'repulsion magnet' as it turns. When the bottom repulsion magnet comes around, it should repel the stator block back to where it was resting at the start, just in time to push the wheel again (and then drop back down on to the shelf).
You might have to reposition the bottom repulsion magnet slightly to compensate for the speed of the wheel turning, or the 'run up', or you might have to use 2 magnets - one magnet which is moved away at the start (to hold up the stator block) and another one that is fixed slightly off from where the first magnet was. You may even need a few more magnets before and/or after the main repulsion magnet so the stator block jumps up just in time to give the top magnets a push.
If it does work, another thought was you might have work on the stator housing so there's less friction, or maybe even slow it down a little with something like cupboard draw bracket rollers. Also, the speed at which the stator block jumps up at might be a bit violent, so you might need to fit a stopper above it.
Please keep us updated with your endeavours and I wish you the best of luck.
billmehess
Thank you for your input lots of good ideas here. The answer will be a unique way of manipulating
the stator in and out of the rotor path. The key phrase is in and out.
Again think outside of the box is the key.
Dusty
Bill.
An idea:  When the stator drops, have another large repulsion magnet down below.  Will the secondary repulsion be enough for the stator to rise to some kind of a latch, which will prepare it for the next transaction?
Dusty
billmehess
Not really there will be just a very slight bounce, but keep those creative jucies flowing.
ramset
Dusty
You fellows have been trying very hard to get things to work
you may have heard  a few weeks ago I met with a fellow who filed a patent app
for a mag motor
I mentioned he had a levitation disc ,a 12 inch circle cut in a piece of 1/4 inch plywood, in the circle was a 11inch [approx] plastic disc hovering in the field
he claimed people could stand on this Disc and not free it from the field
That part I said in a post and yes I held it in my hand [not heavy}
This part I did not say
It was partially disassembled [missing mags that had come out of the glue over time]but still hovering ,only to one side
It just occurred to me what I had in my hand
The disc was STUCK to one side [attraction] because the mags on the other side[that used to pull it back and center it] were missing
Dusty,
Have you ever done this?
It was claimed to be the BIG piece of a motor concept
Before I replicate this [Quite simple concept]
Will it be easier to turn/spin ,floating in attraction
Is it possible that when he says magnets can shield themselves.
He meant, in a field like this??
Did I describe this well enough for you to know what the hell I'm talking about?
Chet
PS
in the motor, he said this same disc would be hovering about 4 inches
PPS
I don't want to waste anybody's time ,as this seems quite simple[but a LOT of magnets] so if you know this to be a dead end please comment
Thanks Grandma
