Antenna design
Started by Elvis Oswald, February 12, 2006, 05:21:33 AM
Elvis Oswald
Suppose you wanted to build an antenna for 7.4Hz - and you didn't want a wire 300Km long... what sort of design and power would you need to amplify a small antenna?
Or... what size / design would be smaller and be at a harmonic resonance?
yes - I am high.   8)
Elvis Oswald
My initial research into this subject has yeilded information which backs up my theory that the HOPE device is actually a powered antenna that is resonating at some frequency that is harmonic with the Schuman Cavity.  More correctly in reference to HOPE... the times when there are 'jumps' in voltage, would be when certain harmonic frequencies are reached.
Note that a coil is a loop antenna.  :)
Elvis Oswald
Schumann Resonances reception, by magnetic component, at less of 50,00 Euro. Is it possible?" The answer is: "Yes, It is!"
http://www.vlf.it/minimal/minimal.htm
IcyBlue
Quote from: Elvis Oswald on February 12, 2006, 11:55:14 PMNote that a coil is a loop antenna.  :)
only if it is an air transformer or has a open flux path, e.g. a ferrite rod. Transformers designs never have a open flux path, because this would reduce their efficiency. So you can regard them as closed systems which hardly interact with anything outside. You can not even couple inductively to a resonant circuit that uses torroidal coils with a dipmeter.
*** Due to recent cutbacks, the light at the end of the tunnel has been turned off. ***
Elvis Oswald
yeah  -  I should have said a coil could be an antenna.  But not in every design.
Isn't it true though that a primary and secondary in a transformer should resonate for efficiency?  The perfect pair would be the same weight of copper - right?  I've heard that said by some people - most notable being Tesla.
Does that mean that surface area makes the difference between ratio of ampheres to voltage?
Two coils with the same mass of the same material - if the secondary has more surface area, then more voltage develops at the expense of amps... and the opposite if there is less surface area?
