Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
quarktoo
Hey loner,
I think that was one of the better posts I have ever read. You clearly have thought integrity and the logic, reason and accountability that goes with that. I have no problem with someone calling me on my bullshit and value that more than 1000 cheer leaders. I get nothing for the cheer leading and the push back keeps me sane and is the other half of collaboration that advances thought.
I intentionally throw stuff out hoping that people will find the flaw. I never respect a believer that just takes my word for it. I get nothing for that.
I have a bunch of stuff people have not seen and would share it with you any day. You have the right attitude. I wish you lived next door. Anyway before I get started, Thanks again!
The power outage was just something that happened and you failed to explore a spiritual possibility. I have perfectly documented experiences that I would not share here that prove these things happen and for a reason. But who knows?
In order for something to get colder, it has to lose energy. (Bohr model of atom) This works in any mass in any state regardless of whether we are looking at freon in an air conditioner or mass of an electronic circuit.
I have been pretty clear all the way through that I don't claim to know much about cold electricity. If fact, since I have not played with it and only read other peoples accounts, I don't know anything about it. Knowledge is experience.
Here is some info. that you may find interesting:
I saw a Russian video where they connected a spider web to a single electrode on a light bulb and the other end to a cold electricity source. The bulb was being held in the had of a scientist.
Protons will not flow through a solid, only a liquid or gas. Conversely, electrons won't flow down an organic spider web or string.
So if the video was real, some sort of static field was probably flowing. Static electricity is cold. An ionic breeze is a no current high voltage and a Whimhurst machine produces a cold breeze between electrodes.
Voltage flows toward the cathode and so logically, one would deduce that electrons are coming from the light bulb and voltage is flowing to it. No? Voltage is cold and current is hot and that is pretty carved in stone.
Now if the current or electron energy and I don't think in terms of point particle physics, rather a wave(s) compress energy into a particle, the wave would have to be distorted.
Now since current is mass, and cold electricity is massless or the mass is self canceling in some way (unpolorized), then we could have a look at a photon to try and understand the process.
What a photon is, is highly disputed but I will throw my version into the ring.
A photon is (was) an electron but instead of spinning in a single direction, it is spinning in two directions like a curve ball. Imagine the earth spinning on its normal axis but now ALSO spin it on an equatorial axis.
Gyroscopic precession will now be present and the Earth will exibit torque upon on itself between the two axis of spin. If the two spins are equal and the mass is round the two torques will alternate back and forth at a 50% duty cycle and give us one a light wave at frequency A. If the two spins are not equal, then we get a different light wave at frequency B.
Why does the photon emit light? Because the two torques acting against each other consumes energy and mass losing energy emits light. This is also why a light wave moves in a zig zag motion. It is also why a photon is nearly massless. It is consuming its own gravity.
So we look at sparks cartoon adn ask why does the photon attract to the electron? Because the photon is losing or emitting energy and the electron is a negative charge.
Electrons are clingy little things and just as sparks stated, when they strike an object, the bond is broken and the electron goes back to the nearest atom that needs one since they don't just hand around anymore than a magnet just hangs around in a pile of nails without attracting some nails.
Now so far most everything I have stated is logical and or experimentally provable.
Next we look at what an electron is. Particle physics has many models. One thing that we are sure of is that for every particle, there is an anti particle.
The ancients knew of the anti particle and that is what the ying yang represents. It is made of two waves and the particle is formed in the middle where the two wave overlap and cup energy. A black hole has a ying and a yang and mass is created where the two tips come together spinning in opposite directions to twist energy into mass.
(Posting this on a physics forum got me banned as a crackpot) :) Fuck em! They can live in their willful ignorance forever!
If you want to look at a model of a photon, look at a photo of the Milky Way. Nature creates using fractals. As above, as below.
http://www.news.wisc.edu/newsphotos/images/Milky_Way_galaxy_sun05.jpg
Notice how the galaxy is spinning in two directions? The central core is spinning 90 degrees to the outer axis? If that were not the case, the universe would be super dooper flat. :)
So now we have to ask ourselves what is cold electricity again? Well look at the coil that he is using to produce it. Notice how the electrons are being spun in two directions? If he were to build his coils slightly different and balance it, he would have it nailed since there would be zero current flow and yet the light which is the force carrier for the electromagnetic force, would be able to flow.
So far everything is logical and can be or has been proven.
So cold electricity has to be light and that photon has to be spinning in such a way that it is not like a photon that we are used to. You see you can spin a ball on a third axis. The light is a force carrier that sinks mass would be my best guess. But wait! There is a third axis and that is the right thumb rule of an electron flowing down copper.
As the light pushes the spin curl, it is exactly like if you were to push a toy spinning top. When you tip the top to one side, the Side of the edge gives it a slight movement sideways. That is what causes right thumb rule.
If he used silver wire and balanced the coils he would probably have it nailed perfectly. I could probably write more about all this and write it better but again, I have zero interest in the subject. Im just here to be lubricated by Ramset. Proof I don't have a life.
I am not sure if you understand what I just wrote because I suck at explaining things but it all makes logical sense.
I offered to help dole but he didn't respond. That is ok by me as I have anti interest in cold electricity.
I intentionally throw stuff out there that I know is wrong or don't believe to see if people will push back. Usually they don't and so I feel they don't deserve to know what I really think.
You on other truly do seem to have a functioning brain and integrity so I will throw you another bone that has been discussed a lot in this forum and that is Meyer info.
MEYER INFO:
Some time back a buddy gave me high res photos of Meyer's circuit boards from the inside of the white box on the dune buggy and the circuit board from inside the alternator. I was able to make a complete schematic of Meyer's fracture generator and alternator as the photos were perfect.
What it taught me was what Stan was NOT doing. There was nothing too special there and so I looked further into what he WAS doing and how he was doing it.
Meyer used accelerators all the way through that dune buggy. The laser in the air gas processor, a process sparks just described in his cartoon, was only one of the accelerators.
If you look at fig. 10-4 of Meyer's notes, you see the word COMPOSITE to describe the wire. The SS wire had a coating of anther metal. One would jump to the conclusion that it was a copper coating but it would have been silver. Good luck finding that wire. It would have to be custom made and that will set off an alarm. The steel keeps half the spin curl from going too deep into the wire. (skin effect) Silver is the most conductive and the oxides are very loose and abundant charge carriers.
Similar to how the photon forces the electron to lose orbit, electrons move in a straight line on silver. The electron builds up centrifugal force as it goes around the coil and is flung off the coil. The bifiler pancake wire attracts it and catches it as it is self inducting and acts like a trap and in the process the coil becomes an electron sump.
The resonance is important because an electron at resonance goes from its highest orbit (term used loosely) to its lowest. At its highest orbit, it has the weakest attraction to the nucleus of the atom and the weakest bond allows the photon to do its trick or the centrifugal force depending on the method used.
Example - When a basket ball reaches the top of its bounce, it weighs zero.
That and the ozone being used to attract the O atom from the water molecule are the parts of Meyer that people missed.
"Nobody ever thought of using an accelerator before" - Stan Meyer
How many years and how many hundreds of times have you seen that posted? :)
ramset
Well Q,
I bought the cavitation thing,seeing the little pistol shrimp made that easy!
I suppose that acceleration would be tide directly to cavitation!
Makes sence [even at 4 in the AM]
I always look to nature as the Urim and Thummin.
Perhaps the acceleration in wind can manifest a tornado?
Acceleration seems to make so many things possible.
Time? I believe time to be a big part of what can change [for usand the elements]] during a really good acceleration event!
Chet
Ps
On a happier note ,a buddy sent me this!
Give it to your Gay /liberal nieghbor!
http://www.youtube.com/watch?v=Ib9rofXQl6w
Oh I'm sure you Know this anyway!
Thanks Grandma
quarktoo
Yep, a tornado is an accelerator.
Look at the base of a tornado. Notice how there are actually a bunch of little tornadoes around the base near the ground just outside of the funnel?
Now look at a hubbard coil...
I made a bunch of edits and corrections to that last long post so you may want to re-read it if you care. I usually do that since that little edit box is difficult for me to spot my mistakes.
sparks
      Proof I guess is in the eye of the beholder unless the beholder is blind.  Then proof would be in the consious experience of what the beholder deems necessary to call it proven  We live in a gray world because between the forces of darkness trying to sequester consiousness and the forces of light trying to increase consiousness there is this gray zone.  It is said you can not serve two masters.  This is true but you can rule two masters.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
quarktoo
I will add something to my photon diatribe to make it easier to understand or offer more proof of the model.
When an electron moves down a copper wire it is spinning in a particular direction, when it hits the tungsten filament, that changes since electrons flow in a straight line over steel and the electron tumbles. Poof! A photon is born.
Gas discharge - as electrons bounce through the mercury vapor, they develop multiple spin axis and poof! A photon is born.
