GIANSONCINI
Started by kenzo60, May 07, 2009, 03:48:26 PM
NEW ENERGY?
YES
0 (0%)
NO
0 (0%)
Total Members Voted: 0
Goat
@ Kenz
I had seen this video posted somewhere before and found it very interesting, I made a loose translation of the info via Google, it's a bit messed up but here goes....
Dramatic decrease of cosmic energy dallUniverso, sconvolgerà that is the theory of its creation (big bang) that the theory of his death by collapsing cosmic (big-crunch), but also the foundations of modern physics.
It follows that much of modern physics should be re-interpreted, for absurdly in the same units of matter, its cause is still unknown reason, that its effect rotating, making them indefinable to one another, and then scientifically not quantifiable.
According to this theory, these causes dynamic orders, separate, separate and external to their various units of matter revealing produce interactive phenomena between the various interacting units of matter, because of fluidico Magnus, thus generating the forces of attraction and repulsion, but also axial and orbital rotations. For these reasons, current methods of calculating forces on the set of electric field, magnetic, gravitational and nuclear, are definitely not suitable for quantification of these phenomena, thus invalidating the foundations of modern physics.
The conclusive demonstration of these statements is given in this experiment the Astrale turbine, rotating in the axial and orbital as the Earth and how the fundamental indivisible particles of the atom, which causes their motives are inherent in this theory, while for Modern Physics these causes are still unknown.
But the scientific community, still under the counter atheism nineteenth turned into "Scientific Communism Dominante" statistically absurd in its conception self-evolutionist, useful to do the massive public funding allocated to them, they will want to consider this advanced and complex theory, completely alien to their ideas and relativistic quantum officially discordant with each other?
Or rather prefer their fragmented and limited experimental method of probabilistic advantage, however inadequate in case of variability phenomenal, and insecure in the quantification of the effects resulting from nuclear collisions detected in undulatory form, starting with hypothetical physical parameters at all certain?
One of the many mysteries that made people talk and get off in dozens of scholars, each in order to prove its case is that of Hartmann's network, named by Prof. Ernest Hartmann, a doctor and professor at the University of Heidelberg in Germany.
After several empirical studies, he developed in the 50s a strange theory that the Earth would be shrouded by a mysterious network or grid is not yet clearly defined by science, whose lines of force around cm wide. 21 and separated them between 2 and 2.5 meters, are directed from north to south and from east to west, crossing at certain points called "nodes".
A technical teacher in Reggio Emilia, Gianfranco Soncini, based on an advanced his theory titled Cosmomodulazione Universal Materia, downloadable from the site www.webalice.it / gsoncini / cosmos, together with the network of Hartmann, the set of Fibonacci and fractal phenomena After complex considerations and empirical evidence relating to the vertical transfer of mass between the multi-frequency grid that move and govern the universal field, has built this turbine astral, even to prove the theorem, which he defined gravitate.
This device is dragged in rotation by an external force, as if it were self-propelled, and then moved from its energy from domestic, should use the principle of jet propulsion.
There being no tricks found of any kind, such energy roundabout based on a cause external to it. But this case comes from an external cause cosmic initial exhaustion, or a result not intended by certain dependent effects in place in the universe, or intended to be a case therefore aimed to axial rotation of the cosmic masses?
We assume that God could not have created the spaces for humans, not provide an adequate source of pure energy to be able to visit, by implication consequent one can say that this cosmic energy, and inexhaustible widespread throughout the Universe Closed that the structure, the moves and governs it, waiting for its exploitation.
This theory is then summarized as follows:
From the very ends dellUniverso closed, along the 3 dimensions of space multi-fluidico continuous, multi-coming waves of energy modulation of multi-revealing indivisible elementary particles of matter, and multi-disruptive energy waves of the same field structure, generating a cyclic order edifying and chaos dispersant, one or the other in space and time cycle.
Edit:  Picture didn't attach...my bad...
Regards,
Paul
tak22
