Unable to account for frequency related to Magnet being pulsed by Inductor
Started by duff, May 27, 2009, 02:08:08 PM
duff
Quote from: MACEDONIA  CD on May 28, 2009, 02:04:22 PM
@duff
i like to ask you something
did you get the  SPINING EFFECKT >  LIKE JET ENGINE TURBINE   ;)
I THING  THE MAGNET FOR <S.M>  DEVICE  IS FOR  TO GET SPINING  MAGNET FILD   LIKE  GENERATOR
I THING  THE POINT FOR  SINGING  OR VIBRATING THE  MAGNET  FILD FROM NEO   IS NOT   <TPU> LIKR   S.M
IF I  SEE DEPER  IN MEANING WHAT  IS   THAT  SPINING  LIKE A JET TURBINE  INSAID THE  TPU
THE RESOLTS IS THE  <....   FROM TPU   STEVEN HAS ALLWAYS  GET FROM HIM  <DC VOLTAGE
BEACOUSE  YOU MAY  SEE  WHEN HE SAY SPINING
SPINING IN ONE DIRECTION   IS ABLE TO PRODUCED  <DC VOLTAGE THAT IS  THE WAY  TO GO AND HOW TO MAKE
NO  SINGING
FORM SOME MAGNET
THE ATHER  TPU
WHIT  PUTING THE TV AND  DRILL TO HIM
THAT TPU IS HAVE    5000 HZ  THAT IS AMAZING  IMAGEN THAT SPEED   OF  LET SAY SOME DC GENERATOR    TO SPIN   5000  TURNS  JUST IN ONE SECOND
YOU AMY ASK  AND THING  IF THE ELKTROMAGNET HO IS SPINING THERE  IS NOT  TO BE NEED TO BE BIG  ONLY VERY VERY SMALL ELKTROMATGNET  WHIT THAT  KIND OF SPEED  WHILL BE ABLE TO PRODUCED  INCREDEBLE   POWER
I LIKE TO POINT  LIKE  S.M SAYS  TO < MANNIX   MOVE SMALL MAGNET  WHIT SPEED LIKE A GUN BULYTH
BUT  IS HARDEST TO  EXPLANE HOW IS ABLE SOMETHING TO SPIN  WHEN WE PUT  5000 HZ  OR LESS OR  MAYBE MORE
HOW  TO SPIN    AND FINALY RESOLTS  TO HAVE   <DC VOLTAGE  I   HAVE  MAKE MAY SOLUTION  DIDI YOU GET SOME  NOW IS TIME TO MAKE SETUP   AND WORKING  DEVICE
THANKS  FOR ALL FRIEND  HERE HO HAS READING THIS
I
Mac,
Yes, I agree the singing magnet is not like the TPU.
I have not tried to get the spinning effect yet. I'm trying to figure out what is causing the 959.4Hz signal related to this vibrating magnet. Perhaps it is a clue.
-Duff
BEP
@duff
If you have not all ready done so, run your FG up to 35.714k. If your magnet screams around 4800Hz then your test is singing the same way my last TPU is.
duff
Quote from: BEP on May 28, 2009, 05:28:20 PM
@duff
I wouldn't be able to hear anything at that freq. - have a high freq. hearing loss.
I did run FG up to that freq and tried. My ear lobe felt some vibs but I didn't hear a thing :)
BEP
Make a small coil to go around your magnet. You should be able to 'hear' it with your scope  ;)
I suspect it will be approaching 4900Hz.
I'm really surprised you are seeing these things with a metal coated magnet AND you had less amplitude with a non-coated magnet (assuming your ceramic was not coated).
Edit:
I suggest your put a resistor across that coil suggested. Don't connect your scope probe to the open coil.
BEP
Just checked my suggestion on mine.
The coil around the magnet must not be tightly wound on the magnet. About a 4mm gap between the coil and magnet should work. But then, I'm using much weaker ceramics.
Just remember, my singing TPU is nothing more than a good weird noise maker. I hope you can do something more with your work.
