Magnetic Field Disruptor FACT or Fiction?Please read-
Started by subgirl28, May 28, 2009, 05:34:27 PM
the_big_m_in_ok
subgirl28 said:
...i just want to get rid of it and buy what i need to buy. if it exists.
>>I was a customer of Loompanics years ago.  They're headquartered in the Seattle area---or were then.
I think(?) the 'Web address would be:
http://loompanics.com
Re-edited answer: Yep, that's the place.  Just like they always were.  They might be able to sell you the means to make the devices you need.
---Lee
the_big_m_in_ok
hansvonlieven
Quote from: subgirl28 on May 28, 2009, 11:31:10 PM
The one reply with the copper soles, sounds great, so grounding myself you say? Would that be only for an electric field? I bought one of those faraday cages but it was like a special mesh material. and it did not work.  the tin foil hat did not work at all I felt ridiculous! LOL  I also tried one of those copper hats from lessenemf.com store.  I cant get it to leave. I will try the copper shoes and see if they can lose me that way.  In one of the articles i read.  A superconducter offers 100 % shielding affects.  What is that? could you explain to me how i can use it to break up a electro magnetic field? Where i can buy or make one. In the mean time thanks for the ideas! ----rc
My apologies subgirl28,
I never thought you would take my post seriously, I was just having a bit of fun with a ridiculous proposition.
Ir would appear you have a fairly serious problem and I hope I have not aggravated your condition with my comments.
If you really think that you have a problem with electromagnetic fields do the following test. There are a number of garden sheds on the market that are made entirely of steel. They are as good a Faraday cage as you can get. Find somewhere where you can go inside the shed and close the door.
If electromagnetic fields influence you the way you say, you should immediately notice a difference.
Do the test and tell me what you find.
Hans von Lieven
turbo
Wrap yourself in aluminium foil and ground it to the water pipe.
If you really want to measure, put in a diode (OA95 or 4148 etc.) and a voltmeter in between yourself and the water pipe.
Most people suffer from the radiation from UMTS GSM HDSPA WIFI WLAN  Digital Television Broadcast etc. High frequency Antennas, check if there are any in your area, or get a meter to measure the field strength.
Marco.
xee2
@ subgirl28
There are cases where peoples bodies do strange things. I suggest you go to a local colledge and show one of the physics department professors what is happening. I think you need to seek expert advice not the kind of stupid ideas you are likely to get at this site.
Groundloop
@subgirl28,
May I recommend Colloidal silver in water. One table spoon in the morning and one table spoon in the evening. Maybe it can help you, I do not know.
Groundloop.
