Magnetic Field Disruptor FACT or Fiction?Please read-
Started by subgirl28, May 28, 2009, 05:34:27 PM
subgirl28
i am not brilliant just a average girl with some questions concerning energy, electricity, and magnetic force fields.  I have something on me and its heavy. It can manipulate air and water.  "it" can manipulate my emotions, make me angry, me cry, make me real sick.  I know its magnetics. and i cant find a magnetic field disruptor.  i really didnt want to say this, but it does talk to me and i swear on jesus I am not crazy. :-[ In one of its stories he called the girl a Joule thief. which i learned here is energy? right. If it can manipulate water it just cant be electric right?  I beleive i have more than one situation.  That the computer holds many of these devices that you call non lethal.  It hates the tone generator that i down loaded from another website. So "sound and noise"  drives it crazy but it wont leave.  How do i change my frequency?  Would a AM transistor work or make it stronger? Because its able to manipulate my car radio and my tv.  Any answers would be greatly appreciated. I hear about a magnetic field disruptor and would like to know where and if they exist.  to sum it up how do i break up electromagnetic signals? how do i get rid of electromagnetic waves?  Is this the same as the microwave technology? Please help and your answers would be grealty appreicated.  I know i asked alot of questions and you may not be able to answer the whole post. i will gladly accept any answers. i just want to get rid of it and buy what i need to buy. if it exists.
0c
@subgirl28,
I think what you're looking for is called a "Faraday Cage". I hope you're not claustrophobic.
It sounds to me like you need to change your resonant frequency. This can be done by either altering your inductance or your capacitance (or both). I suggest coils (use silver wire, you can get it at the jewelry supply store, you will only need a few feet) for the inductance and G-10 circuit board material for the capacitance. You might also need some of that aluminum duct tape for fastening.
Take the silver wire and wind it around a form, like a wine bottle, until you have a spring-like form that you can slip your arm into. Cut a small square (or circular, but I think square works better) piece of the G-10 material and put 2 little holes in it about an inch apart. Slide it onto the silver wire spring. This is your tuner.
Put your arm into the spring, like it's a bracelet, and start experimenting. You should be able to find a tuning that alters your resonance enough to stop the bad effects you are feeling. Try clockwise and counterclockwise spirals and gradual changes in the tuner setting. Don't give up too soon! Once you've found the right tuning you can use a bit of the aluminum tape to fix the tuner in place. Don't use plastic or scotch tape, it's not conductive.
I've noticed that the tuning can vary a bit from day to day, I think it might be diet related. Try to cut out all aspartame, NutraSweet, all artificial sweeteners, and no more caffeine. Sleep helps a lot.
You could also try resonating crystals but that's a little harder.
hansvonlieven
Take some thin copper sheeting and fasten it to the soles of your shoes, trim to fit.
Next solder a heavy wire to the copper sheeting and make up two copper bands that can fit around your ankles, like a bracelet. Solder the other end of the wire to those copper anklets.
Wear shoes and fasten anklets ensuring good contact with the skin using a gel.
This will earth you properly and insure that the harmful vibrations cannot touch you. The use of a tinfoil hat is also recommended. It is best if the tinfoil hat is also electrically connected to the copper soles.
It will look a bit silly but this is a small price to pay for sanity and freedom from unsavoury vibrations.
Hope it works for you
Hans von Lieven
BEP
As much fun as some people have with this it is quite real for an unlucky few.
http://www.radiationresearch.org/
http://inthesenewtimes.com/2009/04/13/doctors-warn-on-electromagnetic-radiation/
http://www.emfsafehome.com/elecSens.htm
Thankfully, I'm not one of them.
I know the use of EMR is quite useful in electronic warefare and crowd control by most military groups.
