Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
minde4000
Thanks for the info i_ron. As far as I have seen T had two different toroidal cores: one almost exect specs that I have and one much thinner ring as one of his photos show. His latest/last video had "fat" toroid. I do agree about the smaller size and better material but I guess I will try to get this one going and then go from there...  I am worried about my rotor too wich is different from one you made for T. Oh well. Time will tell. It would be great to get some info from other "replicators" but it seems that people are not too willing to share their projects here so if this way will continue I will go offline too..
Edit: live core size example was clearly demonstrated at T's california christmas videos when his relatively(vs toroid)  small single E core inductance coil combination accelerated in 100rpm jumps wich we didnt see on his latest videos. Probably that particular E coil inductance accidentaly closely matched the rest of his systems specs (magnets strenght freq and etc.) so it gave such spectacular effects.
Edit: on the other hand if I would ever go as high as 16 coils on my core (double sided) the size might not be too overkill at that point.
Regards Minde
baroutologos
I will share my details Minde!
I do not speak so often because i have little time in my disposal so no fast progress is made.
I realize u guys want to continue from there Thane stopped. That's good.
on the other hand i want to fully explore Perepiteia's principles so i start from scratch. that means finding out the accelaration effect a HV coil produces and its potential output measure not in a resistive load but captured in a capacitor etc.
All my experiments will be powered by a pulsed motor for efficiency, since it is claimed and proven that HV coil assist mechanical motion.
You readily realize that all this stuff takes time.From monday i will post pictures of my progress from this pathway.
@minde you are not alone man in this
Regards,
Baroutologos
petersone
Hi Baroutologos
Following your posts with great interest,as I'm sure many are.
Thanks
peter
hydrocontrol
Quote from: baroutologos on May 31, 2009, 02:37:51 AM
Time is only one aspect. $$$ is the other.. both are needed for progress.
Before I got the rotor specs from I_ron I started to build my own rotor out of Aluminum. Not sure that it will work or if the rotor needs to be out of steel for the effect to take place. I machined my rotor to take Radio Shack rectangular ceramic magnets as I had a bunch from other replication projects and they would be cheap for other replicators if they worked. Last week I ordered some N45 round magnets off of EBay so I will need to modify the rotor to accept these as well that way I can try a couple ideas. Before Thane started using different cores I had gotten from EBay several MOT cores that later Thane would later proclaim are only good for doorstops. Bummer..
So far I have spend a good amount of $$$ and have very little to show for the trouble. These "research" projects have to be budgeted for me as I have a limited amount of $$$ coming in and about equal $$$ going out.  ;D  I suspect that is the case for others. The same problem goes for the time aspect of "research". Having to take care of my house (bills, maintenance,etc) and my elderly mothers house also takes time and money. Just last week my van I drive started puking antifreeze in the driveway after I parked it. This weekend a bit of time will be spend replacing the waterpump that is shoehorned in a tight place. Very little time will be spent on "research". Bummer again.
So pardon me if my "research" is slow. We all have different levels of resources available in the $$$ and time area. Sure I wish I did not have to work for a living or that I was retired with a steady income. I could devote more time and $$$ on "research" but at the moment it looks like my loto ticket did not win again.  ::)
From looking at Thanes progress it would appear he had a "sponsor" so that helped him with the time and $$$ aspect. I wish I had a "sponsor" but that comes with a price to pay as you can tell from Thane being silent now.
So I guess what I am saying is that I will be making progress as time and $$$ permit but it will not be at the lightning speed that Thane was doing toward the end. I am sure that is the case for a lot of the replicators.
I will also being posting pictures of my rotor Monday as "proof" I am working on this.
tagor
Quote from: petersone on May 31, 2009, 02:46:39 AM
Hi Baroutologos
Thanks
peter
yes
I , also , am waiting for more data to begin a replication
daniel
