Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
baroutologos
Hello at all
For me talking and reaserching is easier than doing! :P By the way, my Work IN progress pulsed motor-perepiteia outline could be encapsulated in thoses photos.
As you can see, i am form Bedini's school of crafting, so goes the outline. (coil's cores, SSG pulsed motor, minimum metal usage etc)
Regards,
Baroutologos
hydrocontrol
Here is the start of my replication. Takes Radio Shack rectangular ceramic magnets or the new 1.5 inch ebay ones that hurt like heck when they pinch your fingers ;)
wattsup
@i_ron
I fixed the @TK thing. Thanks.
Regarding what @minde4000 just posted, looking at those empty spools destined as the coil holder I imagine. My question is pretty simple.
If the core going inside that spool is there to initiate some level of coupling that will be transferred inside that huge bottom core, is it not better to have the best coil to core fit possible. If you had a square core inside that round spool center, there is no close coupling possible. Or is this part of the overall effect having a semi-core with semi-air-core coil?.
If the effect would be better with square core with square and tight fitting center spool, maybe there is a way of heating the spool center plastic core, putting the square core inside then reforming the plastic to fit snugly around the square core.
This core reminds of some stators I saw on ebay today, here is one of them. Could this be used in some way as a low cost startup for components.
minde4000
@wattsup
I agree square coils would be better but for start I will go with what I have. These coils will have either silicon steel or tape square cores and will be attached to the toroidal core wich is too big also. My coil sizes cores and ring should closely match last thanes video setup. Rotor will be different. Once I will get this setup going (IF) then I will start modifying if finances will allow :)
Minde
baroutologos
@ Wattup
yes you say it correct. My green spool is Litzed wire (18awg) destined to become th pulse motor section.
@ ron
speachless..
@all
currently i am having some difficulty in seting up the motor section of my work at obtaining some 2000+ rmp with one core. (note cores are iron wires, laquered)
I would had not trouble if the motor was a radial one but... for safety's shake (magnets on the rim tend to fly) made it a axial more inefficient one.
Anyway, as i repeatedly said, i plan at exploring Peripeteia in a micro basis, few watts input, so as the effect of HV coils to become the prevailing factor in this setup.
If progress made, i will soon post it here.
Regards,
Baroutologos
