Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
Pageygeeza
QuoteTrailblazers creating new trails need to put up more markers and create better maps
than they think is probably needed for the job. Likewise, hikers on new trails, without a well worn path to follow, need to be able to read maps and follow markers, all while resisting the well intentioned urge to fill in perceived missing markers. Any failure in this system, and the hiker will never agree that they reached the same destination as the trailblazer. Ideally, the first hikers should compare notes with the trailblazer, and be able to mutually accept ideas for improvement.
That analogy is probably the best I've ever heard, you couldn't be any more accurate with it. :)
Me?  I'm just creating my own peaceful personal trail in the most wonderful part of the world. :D
Another thing you forgot to add:  The more hikers you get, the bigger the mess, unless they clean up after themselves.
CRANKYpants
Quote from: derricka on June 23, 2009, 06:02:34 AM
"BlindMouse3"
QuoteBut aside from the stupid remarks a fairly decent post for a change,
More like it would be appreciated,
Ron
IF AT FIRST YOU DON'T SUCCEED - GO BACK AND FOLLOW THE INSTRUCTIONS
HERE IS WHAT PEOPLE SHOULD DO TO REPLICATE THE THANE HEINS PEREPITEIA PROPERLY.
1) DON'T LISTEN TO I_RON.
2) DON'T LISTEN TO HOPTOAD.
3) WIND A HIGH VOLTAGE COIL ON CHEAP STEEL IRON BARS FROM HOME DEPOT LIKE LARRYC.
4) USE AN 18 POLE ROTOR AND WIND A SERIES BI-FILAR COIL.
5) PUT ENOUGH TURNS ON UNTIL ACCELERATION STARTS WHEN COIL SHORTED. IF NO
ACCELERATION ADD MORE TURNS UNTIL IT DOES OR RAISE ROTOR SPEED.
6) 30 GUAGE WIRE IS BEST TO START WITH - 100 OHMS WOUND TIGHTLY SHOULD WORK.
7) THEN ONCE YOU HAVE A GOOD IDEA OF WHAT IT TAKES TO GET ACCELERATION WITH CHEAP CORES - UPGRADE TO GOOD TRANSFORMER LAMINATIONS.
REPEAT STEPS 1 - 6
9) NOW CHANGE THE GAUGE OF WIRE TO 22 GAUGE AND REPEAT STEPS 1 - 6.
10) NOW ADD AN EXTERNAL LOAD TO YOUR COIL - START WITH 1 OHM, 10 OHM AND UP UNTIL ACCELERATION DISAPPEARS.
11) NOW YOU KNOW THE LOAD OPERATING RANGE OF SAID COIL.
12) NOW GET A STEP DOWN TRANSFORMER AND STEP DOWN THE HV OUTPUT FROM YOUR ACCELERATING HV COIL.
13) MAKE SURE THE TRANSFORMER DOES NOT REMOVE THE ACCELERATIVE EFFECTS
14) NOW ADD A LOAD - A LIGHT BULB IS NICE BUT YOU NEED A LOW RESISTANCE LIGHT BULB IF YOU ARE GOING TO MAINTAIN ACCELERATION.
15) THE LIGHT BULBS FROM THE RYOBI BENCH GRINDER WORK WELL BECAUSE THEIR RESISTANCE IS ONLY 2 OHMS.
16) IF YOU GET THIS FAR YOU WILL HAVE A PRETTY GOOD IDEA OF WHAT IT TAKES TO CREATE AND MAINTAIN ACCELERATION UNDER DIFFERENT CONDITIONS - IF YOU FAIL ANYWHERE ALONG THE WAY JUST SAY IT'S ALL A HOAX.
17) NOW YOU CAN TRY AN E CORE.
18) TO MAKE AN E CORE WORK WELL YOU NEED TO MAKE ONE BY HAND FIRST ALSO IT IS A GOOD IDEA TO USE CHEAP STEEL EARLY ON AS WELL.
19) MAKE THE INNER E FINGER FIRST AND GET IT WORKING.
20) THEN MAKE THE OUTER E FINGERS - WIND HV WIRE ON THE OUTER E FINGERS.
21) MAKE SURE THE INNER E FINGER LAMINATIONS ARE TURNED 90 DEGREES TO THE OUTER E FINGER LAMINATIONS
22) YOU CAN ALSO MAKE A MODIFIED E COIL WITH AN INNER HV COIL AND THEN AN IRON PIPE AROUND THE INNER HV COIL WITH HV WINDINGS ON TOP OF THAT - LEAVE THE BACKING PLATE OFF FOR NOW.
23) THE ROLE OF THE CONCENTRIC E COIL IS FOR THE OUTER CORE TO COLLECT THE INNER COIL'S DISCHARGING FLUX AND VISE VERSA.
24) THE INNER HV CORE AND THE OUTER HV CORE MUST LINE UP CORRECTLY WITH THE MAGNETS ON THE ROTOR OR IT WON'T WORK. IT TOOK ME 5 SOLID WEEKS TO GET IT RIGHT - IF HOWEVER IT DOES NOT WORK FOR YOU THE FIRST TIME THEN JUST SAY IT IS A HOAX.
25) NOW ONCE YOU GET THIS FAR MAKE A BI-TOROID HV COIL WITH DUAL ROTORS - SIMILAR TO THE ONE IN MY EARLIER BASEMENT VIDEOS. THERE IS NO AIR GAP BETWEEN THE COILS AND THE FLUX FROM ONE COIL GOES RIGHT INTO THE OTHER - AND YOU GET ACCELERATION.
26) ANY PROBLEMS ALONG THE WAY - TALK TO THE MAN IN "CHARGE" OR SEND ME AN EMAIL @ thane_heins@yahoo.ca .
T
Pageygeeza
Or, don't be a sheep and come up with your own ideas. :)
Thane, you're not the only one working on your own idea.  What's the point of being an inventor if people have to follow someone else?
hydrocontrol
Quote from: Pageygeeza on June 23, 2009, 09:11:41 AM
I believe the point that Thane is trying to make is that in order to understand the effect you need to have a starting point. Once you can replicate the effect there maybe numerous ways to achieve the effect. Most new inventions are based upon older inventions and ideas so you need to have a valid starting point. A working independent replication of an existing idea is a valid starting point that can be expanded upon and improved. I have yet to see Thane state that his setup is ideal. It just happens his setup is working so that is a starting point. Thane has also released videos, his theory of operation, and is working on improving his setup based upon his experimenting. This seems to be all very positive. Thane is also trying to give a simplest guide for replication with his posted steps is the previous post. Once again this is positive.
  You may have a better design or invention but you also have indicated that you are going the commercial route in order to make some money off of the design. That is all fine by me but what is the point of making a statement of having a better design or idea if you are not going to show or share it here. It ends up looking like a lot of smoke without any real substance.
Pageygeeza
Good point, but the whole thing is very two sided.  Either you go private and have people not believing you because you can't provide the proof.  Or provide the proof and no one wanting it because it's gone public and everyone has access to the information.
Watch this space.............
