Where will the energy come from, to run a Magnet Motor?
Started by TinselKoala, June 06, 2009, 02:06:20 PM
onthecuttingedge2005
Quote from: lumen on September 19, 2009, 08:56:43 PM
Where does the energy come from?
From what I have found it follows standard physics calculations with only a one change.
If I have a 1kg mass and ask how much energy will I get if I drop it? Well the question then is, how far will it fall? and the answer is it will fall forever!
Using gravity,this is impossible because it will soon run into something and stop it, but this is not true with a magnetic field.
In a magnetic field, a path can be made to "fall forever" and simply produce endless output in a way like electrons in orbit around an atom.
Hi Lumen.
are you making this up as you go a long or did you read this some where?
Jerry :)
lltfdaniel1
If there is a delay in electric, then there is a delay in magnets.
In the world of energy it is all uttered.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
newbie123
Jerry,
Exactly.  That's what it meant by  "not orbit"  .. The "electron's motion" would have been more accurate... or density/probability.
Until you can measure it, arguing about something can be many things.. But science is not one of them.
dankie
Who cares about magnet motors , they are too expensive to machine .
Forget about magnet motors , you will waste your life and $ .
And plz , stop acting like you knew wtf you were talking about .
lumen
Quoteare you making this up as you go a long or did you read this some where?
It is what I found in an experiment I did. I then constructed the path in Maxwell and found it to actually produce a constant force of a very significant amount, much to high to be error.
I am in the process of building the device so I can confirm the results in practice.
The partial device I built does already confirms the principal of operation but I will need to build a fully functioning device before I would believe it operates.
I can say this, all forces are balanced, the device does not use any push or pull from the magnets to operate and in fact it is required that the forces are balanced and not used for motion.
I have lots of data and field renderings on this method of operation, and I cannot find anything in the path that causes it not to operate.
So at this time I will continue on with the impossible!
