skwwwks's youtube channel: inertial propulsion.
Started by broli, June 12, 2009, 06:36:12 PM
I found this true gem on youtube. You can watch all the videos here:
http://www.youtube.com/profile?user=skwwwks&view=videos
It's all about a mechanical inertial propulsion system. The airbed experiment and the hanging platform experiment are quite impressive. The green videos seem kind of very old while the others are newer.
Thanks, broli. Added to my "favorites"!
The green ones are mostly about the Tolchin devices, in several incarnations. Some of the later ones (the domed, beetle-like devices) are the work of Gennady Shipov and his collaborators, carrying on the Tolchin work.
The air track and table demos are impressive. But unfortunately, to my knowledge, these devices still fail the "pendulum test". The center of mass, when carefully tracked, still averages out over time to be motionless. The devices cannot sustain a constant deflection of the center of mass when suspended as pendulum.
I met Shipov in 2000 or 2001, and tested a small mechanical Tolchin device that he brought over. It had three wheels and the paired offset weights, driven by clockwork. It would lurch along nicely, and Shipov claimed that it would do the same on an air table. I didn't have an air table at that time, so I borrowed a machinist's surface plate, leveled it precisely, put a couple dozen marbles on top, and a piece of plate glass on top of that, with the plate glass weighted to the same weight as the Tolchin device. Then I put the Tolchin machine on the glass and started it up.
My reasoning was this: If the device worked, as claimed, by interacting with "torsion fields" and was truly a reactionless inertial propulsion drive, it would go happily along on the plate glass and the glass would simply sit there motionless. On the other hand, if the device worked according to Newton's laws of motion, that is, normally and not as a reactionless and/or inertial propulsion drive, the Tolchin machine should go one way and the glass the other, with the Center of Mass of the system formed by the glass and the device remaining, within experimental error, motionless.
It's amazing how angry people can get over a simple control experiment, performed right before their eyeballs with ten dollars worth of apparatus.
TK that doesn't quite answer the video with the two guys and the air track. As far as I know you could have just made this all up. But hey it won't matter, as the videos do the talking.
Yeah, I made it all up. You got me. You're looking at the future of spacecraft propulsion (and free energy too) right there in those videos. Newton's laws, Conservation of Momentum, all that obsolete stuff is out the window, the proof is right there in those videos.
And the machines are very easy to build. Much easier than magnet motors. And you will have the gratification of actually seeing something make progress across the floor, or even "losing weight" when placed on a spring scale.
So I encourage replication, before the Powers that Be suppress those videos and banish Shipov to some Japanese island somewhere.
ramset
And thats why a guy like TK is worth his weight in gold around these parts
[Quite serious]
Chet
Thanks Grandma
