Magnetic motor?
Started by helioc, June 16, 2009, 06:49:50 PM
lumen
I am quite sure that video is not working as suggested. It looks more like it requires an exact speed to sync to an AC line nearby.
helioc
Quote from: lumen on June 24, 2009, 05:57:28 PM
so, this rotor moves.... and you, who get this rotor move? there are energy?
Its my point...
Low-Q
Quote from: lumen on June 23, 2009, 07:46:45 AM
Low-Q, I have been doing some measurements on a similar setup and found a condition that looks like a possible OU condition.
I do not want to say to much at this time, but the data shows significant energy gain. I may actually be on the same path as STEORN so I should not say too much unless I develop a fully operational device. Something they have not done.
(I have indicated the NS polarity incorrectly in the example)
When you do measurements you must look at the force versus distance in any possible configuration. It is easy to be fooled by a great force versus a weak force when you do not consider the "active area" where the force is present. A weak force over a great area, can represent as much energy as a super force within a very small area. In the same magnetic setup, these two alternatives are allways the same.
To make a magnet motor working, you must remove and add magnetism so you can alter the flux density without altering the active area the flux is working within. To add or remove magnetism, will require energy in one or another form - like altering the current through a coil.
Anyway, God bless the person who finds a way to make these magnetmotors working :-)
Vidar
Low-Q
Quote from: helioc on June 24, 2009, 03:45:27 PM
LOL
and now??? hem??  :D
www.youtube.com/watch?v=YJncWgvW5ro
I have seen this video before. Permanent magnets does not have to sync in order to work in a regular DC motor. As the magnetism is present all the time, permanently, this motor should not be possible to stop - it would keep going as soon as the inventor release the rotor. The RPM should increase untill the energy spent to overcome friction and air resistance are met. But this motor is rotating with a constant speed. It is very possible this is a fake. Not only because magnet motors can't work.
Vidar
