permanent- & electromagnet motor
Started by mcsquare, June 21, 2009, 04:38:31 PM
mcsquare
Hi, all.
I would like you to have a look at this.
I'm a newbe, and I have superficial knowledge on the scientific principles of magnetism.
But I was playing around with four small magnets stuck on a CD, each with their north to the same
side and I saw it was incredebly easy to have it spin with a fifth magnet pulsing at the right moment
to repell. So I thought the spinning could generate the power to have an elecromagnet pulse at the right moment. Maybe have the electricity generated by the spin fill a capacitor or a coil, like in cars
then at breaking the circuit, use the higher voltage to have an electromagnet pulse to repell the permanent magnet on the disc. Their will surely be more electronics involved, maybe a battery
or so, but before to start a bit more serious try, with car-parts I was thinking, I'd like to know what you guys think, or maybe someone has already tried this?
jas_bir77
gravityblock
Quote from: jas_bir77 on June 22, 2009, 04:25:54 AM
look up adams motor he eas one of the pionears.
at http://www.rexresearch.com/1index.htm
What mcsquare posted is not an Adams motor.  You will learn a lot from researching the Adams motor though.  I like your design mcsquare.  Research the Muller Motor also.  It is similar to the Adams motor.  Not sure if I spelled Muller right or not.
I have built an Adams motor without the cold electricity or Over Unity affect.  It is one hell of a Pulse motor though.  Maybe If I added more than 2 stator coils and more than 4 magnets on the rotor that I currently have with a better mechanical switch and get the timing right, I may notice the "cold" affect.
It is essential to follow the instructions to the very letter if you decide to build the Adams motor.
Good luck,
GB
mcsquare
Thanx for the replies (was a bit afraid for "oh this has already been tried", forget it, won't work")
I will surely get into studying Adams and Muller (Müller?) But what I would like to built is the idea
I scetched in the 3d program, start with an alternator, an inductive coil, some strong magnets and
lots of copperwire...
Last night I was reading about Bedini motors, and their is some similarity with them too.
Oh, so much studying to do. I hope we can make this generator work, hope you will all help me when needed, hope to share with all if it works.
Oh, this has already been tried, forget about it, it won't work.
There, feel better now? I certainly do.
:D
(They are fun and educational to build, though. Here's one that doesn't generate anything but is alleged to have no armature back reaction, thanks to Stefan Marinov and Sergei Nikolayev.)
