0 Members and 145 Guests are viewing this topic.
xenomorphlabs
Quote from: Omnibus on March 24, 2010, 07:24:16 PM
Indeed, all seem pretty similar. All in all that's Tesla coil concept. Problem is, do they really amplify energy or it's just a seeming effect due to tapping into a known existing source?
Without knowing the power input values like Gyula said, it is impossible to know.
According to Melnichenko and others, there won´t be an amplification when the load is directly connected and is not taken special care of.
Quotehttp://www.youtube.com/watch?v=iWZpyT04Fcs&feature=player_embedded#
hmm anyone understants German ? can write short notes about video ?
Would be a waste of time, the guy is most likely a fake and mysteriously "disappeared". If you look for pyramid energy on this forum you can read all about the guy.
Quotehttp://www.youtube.com/watch?v=NkZ10Ys8-NY&feature=related
If one knows german let he wirte notes !!!
Dude there is a whole section on this forum right here dealing with the Testatika:
http://www.overunity.com/index.php?board=22.0
If in that section the video´s info is not discussed.
He talks about modulation of high frequent oscillators and the possibility to couple low frequent oscillations out of high frequent ones and the other way around.
Concerning the grid he sais that the grid simultanously reflects two things: a high voltage low amperage and low voltage high amperage.
He makes particular mention of down-modulating MegaHertz oscillations into low frequent oscillations to enable them to flow through the whole coil and not "break out" and makes the analogy of a heat pump system.
The guy is very knowledgable in the EM-field. We should hire him for a Kapanadze replication  ;D
grizli
grizli
Quote from: xenomorphlabs on March 24, 2010, 08:16:38 PM
That is EXACTLY what we need.. and what probably KApanadze  use: combining high current and high voltage together.
baroutologos
@Grizly,
Instead of over-theorizing, go build Kacher and see yourself. ;)
I have built mainly two Kacher editions, from the diagram given to me by rutube user Destine and it is the very diagram the Administrator posted some posts ago (secondary' end go to transistor base)
I did some extensive experiments in primary voltage ranges (12-24-35v)
It indeed lights bulds using a solid ground very much, but it consumes a lot! Mine consumes (this tested with over a dozen transistors since i keep burning them from various reasons) some 40-100 watt.
Bringing a incadescence lamp to brightness is around 40-50% efficiency at mine setup that is the suggested setup (24awg-1000 turns secondary all same other part-specs)
I have been told also the Kacher takes same 25 watt input (mine take as low as that at 12-15 volt and good adjustment of the primary coil) but cannot light a incadescence lamp. Whoever has claimed that has not provided any proof. period.
IMO kapanadze device has little if any resemblence in principle of operation as the kacher or a pure Tesla coil.
I believe and I express my personal view that Kapanadze device does not even uses smooth resonance as the Kacher does, but somehow (assuming its true) amplifies capacitatives discharges over a network of coils.
ps1: Imo this particular device (replication) should entail some resonance action, but from the visible components (1-2uf cap and air core coils) its resonance frequency goes well to Kilohertz range rather than 50-150 Hz for stealing the grid pursposes.
ps2: The original replication video removed
Omnibus
@baroutologos,
That's very interesting what you're saying. So, the well known effects of the Tesla coil can be readily demonstrated, as we saw in a number of videos. However, the energy amplification doesn't seem to be straightforward thing to do let alone understand what its character is and whether or not it's something trivial. I have a high hope that those Bulgarians will soon shed some light on that. Wonder what's the story with Smith? Is he open to visits and open discussions or he's another Kapanadze? Where is he located if I may ask?
