0 Members and 164 Guests are viewing this topic.
grizli
Quote from: xenomorphlabs on March 25, 2010, 10:18:25 AM
That can be due possibly introduced by resonances in the waveguide (iron tube inside the coil).
I really doubt thats waveguide ? does he claim that ?
baroutologos
Xeno:
The electron disturbance along the wire introduced by the dipole (big coil) is probably causing the ions in the wire to oscillate. It needs no closed loop to do that (antenna principle).
Xeno, single wire electron oscillation can happen as long as there is a capacitance that generally the free wire possess. This coupled with the fact that typical antennas operate at Mhz range then a considerable current can oscillate back and forth.
In the Kapanadze device for reasons i fore-explained there is neither a high frequency to justify the large current neither huge one-wire terminal capacitance nor excessive voltages (tens of kilovolts range)
Actually you can calculate your own the amperage movement in a "single wire" by multiplying the Capacitance  * Frequecy * Voltage on free terminal. (generally single terminal capacitance is on the pf range).
Then you will come to my words ;)
grizli
imagine we have capacitor we want to charge....
when capacitor is empty current is maximum and current drops exponetiall, voltage is minimum and rises expeonetially
on the tesla coil at the bottom is maximum current and at the top is maximum voltage and low current..
imagine we put capacitor in series with secondary tesla coil one end of capacitor is ground other is bottom of TC secondary.. capacitors capacity is BIG and it acts like short circuit at TC working frequency ..
We presume that TOP of TC does not give too much voltage for example 10-15kV max.. not too many turns...
at the top we connect low capacity capacitor (proabyl few pF that makes good LC resonance for secondary )  one end is at the top of TC other is conected via HV diode to top of capacitor or bottom of tesla coil secondary
maybe this particualr circuit will not work but we want on the capacitor in the same time high current and high voltage in phase ..
edit ; at the bottom of big capcitor   is diode oriented to ground... hmm
xenomorphlabs
Quote from: grizli on March 25, 2010, 10:23:26 AM
This claim is STUPID ( Smith claims special components required) he just wants to make money !!
CAPACITOR is capacitor diode is DIODE and wire is wire !!!!
Primary is 0,2uF = resonance not more than 300khz.. no NEED for special caps .. classic HV caps can work .. probably  chermaic HV or oil HV will work nicely !!!
DIODES you dont buy you make them using ultrafast 75nS 1A 1000V diode in series one costs 0,1$
but on youtube there is Smith video of device that woks, demonstration.. the same device has detailed photograph.. ALL whats in on build-plate you can SEE !!! nothing is hidden
A diode is a diode?
Think for a second about the following facts:
Smith writes in his documents that he has devices that work at 6 MHz,60 MHz and 220 MHz. I was refering not only to the table device, because it is most likely designed to confuse about the correct interconnection.
Show me an off-the-shelve 80 kV high voltage rectifier that can handle these frequencies.
Smith explains in a video lecture that the diode bridge in his table device
was custom made and has 2ns recovery time at 80 kV.
I mean if you manage to successfully replace that with 80 in-series 75nS diodes, then everything is fine.
Smith had no big business selling components at all, so how can he try to make money with that ?!
The table device was NEVER demonstrated by the way, it probably does not work. But this has in-depth been discussed in the respective Don Smith threads in various forums.
It is incomplete even, because the output transformer is missing.
The only public demonstration EVER was his suitcase device (for a few minutes).
It is better to discuss D. Smith related stuff in the D. Smith threads,
because after all this thread is about Kapanadze.
grizli
Quote from: xenomorphlabs on March 25, 2010, 10:52:24 AM
A diode is a diode?
HE CAn write WHAT ever he wants i JUST see his capacitor is 0,2uF in primary and at 5 turns primary it gives ABOUT 300khz resonance NO 6mhz nor 27mhz !!!
SO it means all his shon device is LIE or fraud !!!!
If so than we have NOTHING about Smith nor we can replicate him ... really .. i dont see reason why would he use 27mhz...
RF diode are ALWAYS shotkey.. they are NOT HV and can NEVER BE HV, and smith can not produce it nor create it.. i just see cheap hv diodes on his device ... why = because his device works at about 300khz !!!
maximum shotkey RF diode is 125V standary... for 80kV you would need TOO much of them in series, and probably they can NOT work in series.. like standard diodes..  100V shotkey can have pS range and it can be done by maybe connecting them in series, i am probably 90% sure they can NOT work alone in series, if we add capacitor to even voltage across each shotkey we SLOW diode.. if we add resistor we probably do other unvanted things..
So far I have never seen HV shotkey made by series diodes... i will check if it is possible to be done .. all in all in smith diode i DO not see anything except classic HV diode.. (probably as you claim his table photograph device is lie)
All in all i was 99% "hot" to start making smith replication
