0 Members and 41 Guests are viewing this topic.
Kator01
Quote from: T-1000 on February 23, 2012, 12:05:43 PM
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/95834/ has step up transformer missing to Pentod's Anode
The measurments:
1) On Anode it is 315 V pulsed DC, approx 50mA.
2) The Tr2 and Tr1 are 50Hz 10W transformers, taking 50Hz from the grid. The purpose of them is 50Hz signal source, not power.
3) The Pentod Anode is connected to step up transformer. That transformer connects to parallel of Tr2 and 50Hz phase must match.
4) It was not possible to take precise Amp reading on Tr2, so lets say, it is 10W as maximum per transformer
5) Pendode heating element takes more than 15 Watts when heating and 12W when in working condition.
6) The 100W halogen is attached as load.
7) The secondary of Tesla coil is split into two parts: 1st is 1/4 of second coil length. The distance between them on tube is 3.5 cm.
Also, this circuit uses general idea of RF equipment but does not operate in conventional way. There is ionization on Tesla coil going on and there are coil-capacitors inside of Tesla Coil. The Tesla Coil is tunned to 800kHz resonant frequency.
So here is question: is it possible to light and overheat 100W halogen with 16W power input..?
The answer most likely will be shown when you repeat this circuit... :)
P.S.> The longer secondary coil part is winded into opposite direction in regards to first 1/4 length coil. The receiving Tesla coil (inside of transmitting coil) is winded opposite to transmitting Tesla coil.  Also you can have receiving Tesla coil outside of transmitting Tesla coil.
T-1000,
is it possible have a more precise desription and a better diagram as to how the primary and secondary outer coils are connected ? The leads coming from the 315 V + Supply, the ground and the lower grid entering L27/28 also seem to be connected to L30 /31.
I understand that you are using here a Don-Smith opposite-wound coil-design for both primary and secondary coil-sets
Kator01
a.king21
Quote from: T-1000 on February 22, 2012, 05:00:45 PM
Here is what happen in our laboratories.. :)
http://www.youtube.com/watch?v=sAnfBemgyb4 - Tesla coil secondary overheating diialectric while wire stays cold
http://www.youtube.com/watch?v=x9pAmgCwwFA - Receiving Tesla coil ligting bulb
And circuit attached with another photo from another coil: http://imgbin.org/images/6907.png
This seems to be an exciting development.
1 Can you give us PRECISE details of the coil arrangement please. I have always thought that the secret lies in the coil windings.
2 To avoid overheating you can put a spark gap into the circuit acting as a current limiter or lightning arrestor.
Kator01
stivep
Quote from: firlight on February 23, 2012, 01:29:48 PM
Dave :)
Please read my later addition to my post above you will see official links naming  the same tube  as pentode and as tetrode
Wesley
