0 Members and 238 Guests are viewing this topic.
T-1000
Quote from: cHenriques on April 10, 2012, 07:05:25 PM
hi,
I have a question, I have done tests with this two circuits and I don´t understand why there are this diference
If I use this mounting (conventional) the bulb shines fully
But if I use Avramenko's plug despite the spark gap to be more frequente the bulb only shines a bit
You missed link for capacitive loop with AV plug. Please see corrected circuit and try it :)
forest
Quote from: gyulasun on April 11, 2012, 04:35:07 AM
Hi forest,
thanks for this and I ask the output Tesla coil is a quarter wave long at the 10kHz (suggested) input frequency to have voltage maximum on its top end or it is not needed?  Also, the 3nF capacitor you indicate is your suggestion, it can be any similar value with appropiate HV rating?
Thanks,  Gyula
Gyula
Of course would be better to have coil outputting max voltage at the AV plug but that's the tuning problem only. It should work for any HV if you understand that it's electrostatic induction we are fighting with and it is like tic-tac-toe, you send HV positive tic , ground respond with tac and when you remove pulse there is big TOE and everything is balanced again and no charge separation.That's why I said controlled ground or Kapanadze way.
I just modified cHenrique circuit, of course the optimal circuit would work like two oscillators synchronized.Can't say more sorry.I wonder if cHenrique would be brave to show us results.
jbignes5
 I think you are right that electrostatics is the key aspect. Tesla was working in the electrostatic in the latter days just before his death and started to get promising results. We all know there is electrostatics all around us and it is free for the taking. All we must do is attract it to our device and it will stay around that device for us to use. Hence the use of antennas.
There was an interesting experiment that Tesla did. He put metals of all kinds in the field he was messing with and it excited the metals into red hot charge level. Then he put his head into the device and nothing appreciable happened. I think it was from the same article I posted earlier. This organized static field can be used to excite wires into giving all their current capability.
Сергей В.
ПривеÑ, всем !!
THE BIG MYSTERY OF 19 CENTURY
The currents don't add, but subtract
The question: How to connect load without disturbing circuit ??
ps: h0ttp://ecopower.do.am - Secret OU forum (only for specialists)
