jbignes5
Look at the design of the kapanadze device. The spark is only used to excite the internal coils into producing the static voltages for each ground. This causes a directional flow and hence the ground loop. By the way I don't think you need the ground. Any conductor of substantial size like a heavy copper pipe would work. The more weight the better the outcome. Follow his design it's not hard to figure out. Trust your eyes.
Clue: In Itsu's tests he found out that the metals inside of the exciter heated up. Well this is bound energy and it has no where to go. Give it a big path that is circular and a very heavy current will flow instead of heating up and just sitting there. Aluminum might be the key here but I am not sure about it. More testing needs to be done on this electric field we are using to excite the pathways and to the different types of pathways.. Like Copper, Iron or aluminum need to be tested for flow characteristics.
The lower right hand of the picture is what Kapanadze used. By the way this picture is from http://www.tfcbooks.com/tesla/1919-05-00.htm
So the very internal coil is what kapanadze used. He stimulated the ground with different potentials and a great flow responded which he picked up with another coil on top of it. The very last coil was the exciter.
stivep
My conversation  with Niko form Moscow
You have to press control button , hold it and move wheel of your mouse to increase size ( magnify) image to  read note on picture of analyzer.
Presence of taller stands beneath the 3 out of 6 coils might be due to HV and each disc of stands  acts as insulating plate similar to GLASS TABLE presentation ( but over there  there was glass table as good insulator from the bottom of each coil . If we assume that upper   large disc is insulating disc than lower one will be glass table.
The difference  between TENT and GLASS TABLE is that in TENT there is no visible spark.
Spark of GLASS TABLE  is artificial should not exist and was made for the purpose of blinding people to do not  find out real connection.
The place of spark in GLASS TABLE  should be wire connected to each of secondary coil directly. Than you have close similarity to TENT.
TENT presentation :
Big 40KW motor is not a motor in this application but acts as a 3 phase generator.
There is no load no the motor. Therefore the motor needs high current only when starting.
The concept is to  start it with external power, after  it runs it creates harmonics due to carbon plugs, rotor sparking .
That makes it to create spectral harmonics that will return back from the motor as BEMF
The coils must be than tuned to harmonics .
It would be good if one try to  deliver spark at higher frequency and analyze harmonics of lower spectrum  with respect to its amplitude.
How it differs?
I'm going to check that as I have Spectrum Analyzer.
One of Harmonics is resonating with coils structure.
Than it interacts with the signal from the earth LW
as LW is a pressure wave where mas is not transported but energy only after that medium is returning to its previous stage. But energy was transferred.
The transmitter might be man made transmitter or transmitter might represent natural phenomena.
Marconi did the same till government  "shot him up"
1 billion dollars on today's money invested in my mind it  was very carefully thought prior to it.
Oil guys and energy guys did not want that to the day light.
So why they  did not shut down Marconi at the very first day of Marconi California Power Plant creation?
Well they wanted to know  what it is about and how to do it prior  to  any action .
That might explain creation by government RCA that build building in 1919 on  lot occupied by Marconi. To see what he is doing.
Than two years later they made decision to formulate  end of Marconi.
That might be the same people that turn back  Wireless transmission  to Tesla but only after his death. They made their money on communication and they end up paying nobody back ,
Nor Tesla
Nor Marconi.
Eric Dollard (1988)
The Tesla Marconi Wireless System
a. explanation  and presentation of place where  Marconi Longitudinal Wave power station once stood and reminding fragments of it.
b. LITERATURE AND SOURCE ATTACHED TO THIS  PLACE
c. theory  and practical apparatus schematic of  above.
d.Political pressure and decisions leading to confiscation of site and closure of facility.
e.analysis of the structure and its basic functions .
http://www.youtube.com/watch?list=ULUGOTJ0SZN70&feature=endscreen&NR=1&v=bUFaSGg_efY
For me
Device of TK is a receiver and receiver only.
That is using Longitudinal wave transmission to intercept signals from outside.
That also  might be one wire transmission where transmission is done by earth  acting as wire.
Please read article from 1999.
TESLA'S BIG MISTAKE?Sept 1999 William Beatyhttp://amasci.com/tesla/tmistk.html
I have impression that some of you just wait for ready answer.
I'm working  many hours a day to prepare material for you
I need your cooperation
I NEED YOUR ATTENTION.
wheter is critical or  supporting does not matter. The matter is progress.
I'm giving you  so much, please give me some of your thoughts in return as well
Wesley
Zeitmaschine
Ignitors?
An ignitor gives a few HV pulses per second (around 6):
http://www.hisupplier.com/sell-694017-HID-lamp-ignitor/
Hence what is this good for in Kapanadze device context?  ???
stivep
Quote from: Zeitmaschine on June 29, 2012, 11:25:31 AM
Ignitors?
The ingitors where  powering sodium street lamps my friend.
As the low frequency? ??? ??? ???
Shumann effect uses 7.85Hz
TK told me  personally, talking about manufacturing with me Hydro electrical devices employed as Air Conditioners
QuoteALL YOU WILL  HAVE IS 16HZ
Than he repeated  it. Only one frequency you will see that will be 16 Hz.
Well 16 Hz is second  harmonic of Shumann effect.
My position was technology must be released to humanity prior to me acting as  a party in it.
8+8= 16 Shumman Effect.
At Shumann frequency  Ionosphere  reacts as mirror reflecting RF without the losses
Than air in between  earth and ionosphere  acts as waveguide exactly like coaxial cable for your ham radio antenna.
Look  what is slotted line and how it works
http://www.ebay.com/itm/General-Radio-Genrad-Precision-Slotted-Line-900-LB-/140596117231?pt=LH_DefaultDomain_0&hash=item20bc2e7eef#ht_500wt_751
Educate yourself my friend as I'm doing every day,and I will gladly take your help. Anyhow It is very valuable question you ask.
So basically by immersing antenna into slotted line we are able to get energy out.
Wait a moment? ??? ??? ??? ??? ??? ??? ??? ??? ?
Can we have similar situation in the earth?
Read again Tesla big mistake article//////////////// http://amasci.com/tesla/tmistk.html
How about core as one side of coaxial  slotted line and air on the surface as the second border of slotted line ..........
Interesting.............
isn't that that we have  http://en.wikipedia.org/wiki/Telluric_current
Telluric current that was used in early days of telegraph  as free energy source?
and
Quotetelluric current (from Latin tellūs, "earth"), or Earth current[1] is an electric current which moves underground or through the sea. Telluric currents result from both natural causes and human activity, and the discrete currents interact in a complex pattern. The currents are extremely low frequency and travel over large areas at or near the surface of[/size]Earth
so if:
QuoteThe currents are primarilygeomagnetically induced currents, which are induced by changes in the outer part of the Earth's magnetic field, which are usually caused by interactions between the solar windand the magnetosphere or solar radiation effects on theionosphere. Telluric currents flow in the surface layers of the earth. The electric potential on the Earth's surface can be measured at different points, enabling us to calculate the magnitudes and directions of the telluric currents and hence the Earth's conductance. These currents are known to have diurnal characteristics wherein the general direction of flow is towards the sun.[2][3] Telluric currents will move between each half of the terrestrial globe at all times. Telluric currents move equator-ward (daytime) and pole-ward (nighttime).
Than we might have similar reaction to LW.
Only the boarders are different.
QuoteTelluric currents can be harnessed to produce a useful low voltage current by means of earth batteries. Such devices were used for telegraph systems in the United States as far back as 1859.
Interaction of LW with transvesal wave was proven here below and in picture at very end of this post:
Scallar detector.
http://www.16pi2.com/joomla/practicalapplications/magneticscalarwaves.html
QuoteIn the Aether Physics Model, we explain three fundamental qualities of physical existence; electrostatic charge, electromagnetic charge, and mass. Within complex structures, the physics of mass is explained by Classical Mechanics. The physics of electrostatic charge is explained with electrostatics, and the physics of electromagnetic charge is explained through electromagnetism, magnetism, strong force, Van der Waals force, Casimir force, and others.
The seismometer is well known as a device for measuring mechanical waves within the particulate Earth. Similarly, acoustics is a branch of science dealing with mechanical waves of molecules. Nikola Tesla's Wardencliffe system was predicated upon mechanical waves among electrostatic charges. Acoustics, seismology, and Tesla's wireless power broadcasting utilize longitudinal waves. Longitudinal waves are scalar waves, which are measured in only one dimension of length (as opposed to transverse waves, which measure in two dimensions of length).
Although not well known, Scalar detectors have been built for picking up magnetic longitudinal waves. David Thomson independently built a scalar detector, which turned out to be similar to the Dea/Faretto detector. Here he discusses some of the technology from the perspective of the Aether Physics Model.
http://www.godlikeproductions.com/forum1/message612898/pg1
QuoteRE: How are earthquakes/shockwaves/EMP waves/Nukewaves correlated to the magnetic flux (gravity) waves?
David Thomson Aether Physics Model
Word Aether is used as general relativity term:
Just as a tsunami is a longitudinal wave in water, a magnetic flux density wave is a tsunami in the Aether. When pressure builds in some distant star and implodes/explodes, it sends a magnetic flux density wave throughout the Aether fabric, which is all space-time. The only way for that energy to dissipate is for objects with high magnetic pressure to absorb it. Galaxies as a whole will absorb magnetic flux density waves, particularly where their magnetic fields are strongest. Individual stars and planets will also absorb magnetic flux density waves. The greater the magnetic field strength, the more energy will be absorbed.
[/size]
http://adsabs.harvard.edu/full/1996A%26A...312..691N
in this article you have LW and Magnetic tubes
Assignment to tube like pattern.
But if we take that,
this has nothing to do with TK device than let's analyze Earth as 1 wire transmission using LW
Prove of transmission over one wire is  below:
Quote from article:
QuoteTesla's mistake was not really so big. Especially not a big mistake when compared to those contemporary scientists who were absolutely certain that the Earth *didn't* have any resonant frequencies, who *knew* that radio waves would not travel around the curve of the Earth, and who dismissed Tesla's wireless transmission system as crackpottery; as an unworkable violation of known physics. When "Schumann" VLF earth-resonance was rediscovered in the 1950s, nobody in the conventional sciences dared court the embarassment of admitting that Tesla had been right all along.
Tesla is mostly a hero among the non-scientist "underground," while in conventional circles he is still ridiculed for trying to distribute electric power without using wires, or rather, by sending it through the ground. Everyone (still) knows that this is impossible, even in theory.
TK  was also hesitant  so to the nature of the  ground...
One statement:
Quote"Wesley it could be used  on the ocean on the earth in the air."
than I said:
Can we go with it to another location?
TK - yes we can
than I said:
So we will do..
TK- where  I'm going to find the ground connection in terrain.......... you want me to get arrested ?
than I wanted to ask:
You said...... in the air. so it should be also in the car.......
TK  interrupt me as he new that I got him there......
He  start to yell at me, not let me  formulate  this question.
That in my mind was a pretext to hung up on me.......... so he did before I was able to respond.
TK did not lie saying that he is "receiving" energy from "around"
Wesley
Please analyze  frequency of spark form AQUARIUM VIDEO.
Please read again my previous comment on the top  I
have made  a lot of addition to it from the time you  read it.
forest
stiveip
Rest a bit and you will catch it, just relax with nice music , this is all about music...  bells are good
