0 Members and 27 Guests are viewing this topic.
stivep
Quote from: Zeitmaschine on June 29, 2012, 06:35:28 PM
Sure the bank of silver cylinders is not a bank of capacitors?
The label in the video looks almost the same like the label on three phase capacitors from ENTES Elektronik:
http://www.elektrikmarket.com.tr/images
_buyuk/f63/uc-FAZLI-Guc-KONDANSAToRLERi_7663_1.jpg
http://www.entes.com.tr/
Except the »WARNING« line. But the video is from 2007, image shows capacitor manufactured 23 week 2009, hence the label design might have been slightly changed in the meantime.
Strange if igniters have the same labeling.
Street lamps are ignited with Schumann resonance. This is good to know. But how does this effect their power consumption? Or doesn't it?
Let's see:
general information about ignitors:
http://www1.eere.energy.gov/buildings/appliance_
standards/commercial/pdfs/hid_lamps/advance_2003a.pdf
Ignitor 70 - 400 W Metal Halid Vossloh Schwabe Germany
http://www.ebay.com/itm/Ignitor-70-400-W-Metal-Halid-
Vossloh-Schwabe-Germany-/110902508146?pt=UK_BOI
_Lights_Lighting_ET&hash=item19d24dfa72#ht_1774wt_970
Parmar electronic ignitor 35W - 450W Metal Halide / Sodium 220-240V
http://www.ebay.com/itm/Parmar-electronic-ignitor-35W-
450W-Metal-Halide-Sodium-220-240V-/180916045218?_trksid=p4340.m1850&_trkparms=
aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11
%26meid%3D265280102480333519%26pid%3D100011%26prg%
3D1005%26rk%3D4%26#ht_2383wt_1015
Honestly  you made point my friend.
I'm confused
Thank you for pointing me that.
I did not find anything that is close to what you presented to us.
Nature if confusion AND LOGIC PATTERN:
1. existence of spark
-green box   yes
-aquarium     yes
-bed              yes
-glass table   yes.......... relay?    I would say NO it was made up for spark to be there
-tent             no
- presentation to me 200W    no
So if we take "no"
than question is how many time  we have "no" and why.
In presentation to me "no" was because TK used ignitor from gas  stove ( hot water)
Than we did not see spark in tent ...........Niko pointed that it must be presence of ignitors  similar way to what was done  when TK  was doing presentation to me only.
That feed  to logical analysis.
But when he come up to me with his concept of  TK green box than I start to have problem, with his original statement about
ignitors.
I took around  6 months  and we spoke few times consulting each other
Pictures of capacitor and iginors look  very similar.
Niko ( Moskow)
He said that he is telling it to everyone but nobody seem to pay attention to it.
I think I will make video with  it.
schematic is no secret nothing is secret.
For me this concept makes a lot of sense.
I have disagreement with Niko.. Brilliant man.
The nature of difference in  concept is not related  to schematic  but  to earth as energy source based on Niko.
Сергей Ð'. thank you for valuable information.. Cpasibo siergiej.
jbignes5 thank you too.
So if you right my friend that there is bank of capacitors not bank of ingitors  is even  better.
It than matches to NIKO- Wesley discussion about Niko concept.
it will match  also schematic presented by Niko.
FIRST AND PRIMARY THAT WE SPOKE ABOUT IS THAT
-MOTOR in green box
-Motor in Bed presentation with  metal can ( this one is to be placed inside can as a small one)
If you listen to the sound after power is disconnected there is little hiss one second after power is  off for the motor to stop.
- Motor in TENT  PRESENTATION ( 40KW_)
- Motor in Glass Table ( separate room)
-motor in "bed" presentation based on Nico is hidden in metal can with capacitor
- motor in presentation to me........ there was no motor but it was igniter
All of the motors served as generators
all of the motors    have been carbon contact electric motors not induction motors.
All of the motors must of be used as generators of harmonics
Ignitor served as generator of fundamental ad harmonics.
Primary frequency of 50Hz is mandatory.
All that problem that people fighting with  about impurities is for us good. It works ...
Take simple test: connect in ac  single phase motor  with carbon contacts ( the one  giving spark to rotor)
on one leg connect coil "drosiel" and connect it to 220V or 110V AC. try to play with inductance of  "drosiel' and you will see rapid increase of amplitude. The spectral components of signal will try to pull it up.
At given schematic we have capacitor that has coil winded on it .. exactly like  aquarium presentation.. and coil in series.
Coil  in series creates  series resonance circuit. It is not critical what is its frequency of resonance as most likely it will tune to one of  spectral harmonics.
Wesley
MasterPlaster
Quote from: Сергей Ð'. on June 29, 2012, 07:21:30 PM
OU effect of pumping residual magnetization - discovered by Bolotov Vasily Mihailovic in 1938
Effect have been descovered before 74 years. If you get U-shape magnet or same U-shape (electromagnet) marked 4. on drawing and do magnetization with electromagnet marked 2. with help of crosspiece or bridge from soft-laminated magnetic core marked 3. with low hysteresis, you will get boost in remain magnetization of U-shape magnet or U-shape electromagnet.
The inventor Vasily Mihailovic think's that advent of crosspiece of soft magnetic core 3. (for example - laminated silicon steel) make additional additive magnetic but different kind of source primary field of electromagnet 2. In counteract you will get not fall off of net (overall) magnetic field but contrary high rising or boosting remain magnetization of U-shape magnet or U-shape electromagnet.
THIS EFFECT IS WORKING BUT IS HIDDEN FROM OUR EYES. The inventor Vasily Mihailovic haven't got a patent of this discovery and not only on this. That man have several hundred Amazing Discoveries and very few patents. For example one of it is discovery of cold nuclear fusion synthesis in specail radio lams which he haven't patented becouse his discovery is far away from official "science" outlooks. (Better words are official ignorance or official descience). FULL !!
ps. If somebody want to replicate and research this effect my advice is to try several layers or crosspieces of soft-laminated magnetic cores. In one case with same permeability or same susceptibility and in other with different magnetic permeability μ and  susceptibility chi-m properties.
Family Bolotov Inventors Book - The basics of building matter -
Основы сÑ,роения вещесÑ,ва Ð'олоÑ,овыÑ... 2010г.(665 сÑ,Ñ€.).djvu - Русский
Ð"осÑ,упен до: 2012-07-26 06:54:34
Ссылка для скачивания Ñ,,айла: http://ifolder.ru/3131368
Сергей Ð', Thank you for your interesting posts. I think you should start a new thread. The significance of your posts is going to get lost in this messy thread which has gone all over the place and is getting no where.
Shame I can't read Russian.
Much regards
stivep
continuation from previous post:
I'm confused
Nature of confusion AND LOGIC PATTERN:
-green box   yes
-aquarium     yes
-bed              yes
-tent             no
So if we take "no"
ignitors.
Niko ( Moskow)
-MOTOR in green box
Based on Niko that can was glued with silicon to do not move due to motor vibration.
- motor in presentation to me........ there was no motor but it was igniter with all of the spectral components of spark :)
Nature of disagreement with Nico:
I tend to see according to Shumann effect space between ionosphere and earth as waveguide but in the form of slotted line
Any antenna immersed in slotted  line becomes receiver of  energy.
Telluric  current is in the  upper layer  of earth  due to ionosphere earth interrelation.
http://en.wikipedia.org/wiki/Telluric_current
I tend to employ Longitudinal Wave theory
Look at drawings at the bottom
http://amasci.com/tesla/tmistk.html
Compare it to  the drawings at the bottom of this post.
By that token if we could use  approximation
or say speculation and try to invision comparison to it
   than we might  come with very controversial theory.
If the core of the earth reacts as one part of slotted line and the line of the earth and air acts as  second  part of slotted line( borders)
Than any antenna immersed in the ground  becomes receiver of  the energy...
I'm myself shocked with   what I'm writing :)
We might take to account friction in layers   than we can account to energy inside earth
When I was participating with NASA program  in field of extraterestial Exploration of underground of planets and their moons as principal investigator of scientific  team.
I was first working  closely with USGS and FHA DOT in Virginia and in Colombus Ohio with chief  of the department.
Than  I was in Elko Nevada  Murrary Gold Mine
And
Kennecott copper mine salt lake city utah
That gives me a chance to a lot of knowledge in geophysics
I have noticed strange fact  when I put piezoelectric foil in metal enclosure on the earth and connected A/D converter.
On the screen of computer I was able to see natural vibrations of the earth. that was nothing more nothing less than LW.
Than we put that to FFT analysis and used regular photostyler program  to create cutoff the earth to the depth of 2km.
But when I knock  y with the tip of my finger  ground 1" to 5"   next to the vicinity of the probe I have got 10 000 increase of  amplitude of signal from the depth  not interfering with signal from the finger.
We finally got US patent for it and went to  WTC1 to operate with our office. I was president of entity.
Explanation of photographs:
1- equipment used to get cutoff  "picture" of the ground to the depth of 2 km
you see probes ( piezoelectric foil in metal enclosure)
and hammer, later we used just tip of the finger instead of hammer.
Anyhow it was LW,
2. me Wesley holding spike  probe and NASA  chief- guy taking measurement.
3.Third photo  is me fighting with  sensor over  highway in Ohio ( abandoned  voids and mines impact to highway investigation)
despite the fact that there was heavy traffic   finger "work" in there as well.
4. Murrary gold mine deep underground........ Wesley- me :) I was  on the floor taking measurement.
5.ME with USGS guys and reps form Gold mine... just memory picture in front of entrance of Gold Mine.
6.Magnification of LW using hammer.
What geologist might think is that we dealing with implementation of the shock wave and dealing with reflection of it... dead wrong... instead we  have been amplifying passive vibration coming from the ground  by using tip of the finger up to 10 000 times
Take for an example  europe partisans WW2 , or, American Indians  ... metal Railway was a means of communication  by listening to it when you stick your ear.
Earth is enormous  sensitivity  to vibration was explored by me.
That made me  give presentation in Kosovo time to  200 scientists  civilian and military  for Army Rangers  scientific  facility in Columbus Georgia.
recent addition to schematic posted here.
-coil connected to ground is the same coil that guy holds in his hand in green box video.
-Spark gap is influential to create  dirty characteristic in transformer powering motor.
that system  is self regulating
-inverter is connected to DC battery.
There is no "samozapitka" ( self looping) as of yet.
7. think about two motors as one is generator and another one is receiver.
What happened when you stop to turn first one?
How the current in the second one will try to power the firs one?
Mutual interaction isn't it?
Pull- push?
Than look  at Tent  presentation and analyze it this way.
Analyze at first  how device is started.
recent response from  one of you:
Qoute:
Quotethat picture u see clear that those are capacitors for power [color=rgb(0, 0, 255) !important]compensation[/color] look at the picture u will see 3 in a row first one has a wire in each connection point the second two are conectet in series to lower the capacity ... so kapanadze tried to match the capacity for something ...   sorry for pm but i do not afirm myself on the forum because it's already bombarded whit all kind of information . I am am electonist and now i'm working at a company wich makes power factor compesations and i saw alot of capacitors of that type (maybe 25kvar rated capacitors 3 phase )
PS i like your work
So it looks like Niko was not quite right  but  if we say that  Tent  presentation we have had  capacitors than ... where is the spark???????????
That is  very important... Should we understand that  motor by itself due to carbon  sliders  is able  to deliver enough of impurities  to create "dirty   signal" needed by  TK   with  harmonics?
Wesley
leo48
QuoteСсылка для скачивания Ñ,,айла: http://ifolder.ru/3131368
File removed.. >:(   can I download this file on another mirror?. :D
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Zeitmaschine
Quote from: stivep on June 30, 2012, 09:57:53 AM
-MOTOR in green box
A motor in the tin can? This is an extraordinary idea. :D
Although there is no movement visible of the tin can due to inertia when the armature of the motor starts rotating. Seems I have to observe this more closely.
P.S.: What part in the patent description could be a motor?
