0 Members and 371 Guests are viewing this topic.
anandml
Zeitmaschine
Quote from: stivep on June 22, 2012, 08:17:47 AM
Now I have become his biggest worry. He is convinced that I'm the only man in the planet earth that is so close, so incredibly close and is the most educated in this subject to brake the secret.
There should be no problem in educating a few more men on earth in this subject by means of this forum. :)
Tom Talks Tesla: http://www.planetseeder.com/watch.php?mdid=3644
If the principle of work of the Kapanadze device is the same principle as discovered by Tesla over a hundreds years ago (oscillator-shuttle-circuit) and it is the same principle as described by Bearden thirty years ago (The Secret of Electrical Free Energy) then the patent of the Kapanadze device is almost surely invalid due to prior art. If so, Kapanadze knows this and this may be the reason he is reluctant to release the appropriate schematics of his device, because he would gain nothing in doing so (at least in terms of money).
On the other hand, releasing the schematics would make TK certainly a little bit more famous than waiting for someone else to do so (and thereby turning TK into a bogeyman instead of having tied his name with the name of Tesla forever).
leo48
Quotepls translate this circuit diagram......
СÑ...ема принципиальная генераÑ,ора банка = Schematic diagram of the generator of the bank
коммуÑ,аÑ,ор = commutator
Ñ,умбпер   = tumbper
(д+ к3) - клемы коммуÑ,аÑ,ора = (q + k3) - commutator terminals
резонаÑ,ор = resonator
Еспи бобина сильно грееÑ,ся - посÑ,авиÑ,ÑŒ диод = ECFI bobbin strongly heated - to put a diode
резонаÑ,ор медная 40 см на 5 см намоÑ,ана под каÑ,ушками в ценÑ,ре каркаса =
copper cavity of 40 cm to 5 cm under the coil is wound in the center of the frame
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
anandml
Quote from: leo48 on July 09, 2012, 04:19:59 PM
Ñ,умбпер   = tumbper
Leo48
THANKS LEO48
cheappower2012
@anandml,where did you get the schematic you posted?
