0 Members and 357 Guests are viewing this topic.
Farmhand
Quote from: Zeitmaschine on October 23, 2012, 06:45:42 PM
Now, what if the transistors are not transistors (TO-3 package) but thyristors (TO-66 package)? And these thyristors are triggered by neon bulbs? :o
I have found an interesting video about the Tesla hairpin circuit in solid state implementation:
Solid state THP overunity?
A thyristor triggered by a neon bulb replaces here the spark gap of the original Tesla setup. The visible spark gap of the TK device is most likely for showcase anyway, so this would fit the concept perfectly.
This is just to throw one more theory into the ring ... :)
And don't forget to take the Valiums. ;D
Measurement errors I think, looks like what he has is a small coil at resonance. A bulb can be lit under water from a battery just fine, water is resistive.
It's a bit of a confusing video. What is the voltage across the bulb in the water can anyone tell ?
Take a 12 volt battery and a 12v light bulb put it in distilled water and see it light. The effectiveness is dependent of the conductivity of the water, pure water is not very conductive. Then try the same thing with a solution of saturated salt water. It would be interesting if someone determined the conductivity or resistance of distilled water
and the extent of voltage/frequency that can be applied to a bulb in distilled water without causing shock danger.
Cheers
wings
Quote from: starcruiser on October 23, 2012, 02:12:31 PM
@wings, nice that someone is trying to re-patent a Tesla invention huh? I read the patent (first link provided) that relies on a Tesla coil for driving the extra coils placed around the SEMR (Tesla Coil) which Tesla spoke of in his notes and patents.
He might as well try and patent transformers and induction action too
evolution patent of this - FREE ENERGY GENERATOR BY KAPANADZE 100 KW ?
http://www.youtube.com/watch?v=wV560xfYSJ0&feature=youtu.be
or
http://www.youtube.com/watch?v=iapWB2uptaM
xenomorphlabs
Quote from: wattsup on October 23, 2012, 04:01:38 PM
I had prepared a post last night but did not want to post it in the midst of all the commotion. Some of you should take a few Valiums and calm down.
My puzzlement is with the 2004 and Aq2 that must have something hidden inside the TK coil (TKc). It's too bad that @stivep and @a.king21 did not get to look straight through the TKc. When you look at the Green Box TKc, it seems like there is a center placed tube that is off-center from the end. Something has to be there because only two wire coils will not cut it at all. I would say the first winding goes inside the center at half way or another method but something is not right.
In the set-up that Wesley witnessed, the red cable from the PVC box enters the coil at the middle of the coil complex consisting of HV coil and LV coil. So there is certainly something to that aspect.
There is only 2 possibilities. The red cable goes into the coil core and through and exits on the right side or it is used as a winding. The winding thickness looks smaller than the red cable though.
jbignes5
Quote from: xenomorphlabs on October 24, 2012, 03:46:02 AM
The thicker wire going into the coils is a ground reference wire. This is to cause the charges to flow twords that wire but the trick is to intercept those charges with the bifilar receiver coil. This can be accomplished by the radiating outside coil. The outside coil energizes all masses within it's arc and will also radiate outside the arc but in a weaker fashion. This is to cause a flow direction.
In the case of a static mapping of the fields we should see a variable voltage field that gets stronger the closer you get to the radiator. As you pass the arcs of the radiator coil and cross inside the radiator the field pushes the charges into the central point. If there is no way for the charges to exit they will form magnetic lines. But if you do put a coil that will not react to the field but suck each polarity into a unified direction you can harvest any amount of energy you need. Well limited by the matters abilities or attributes.
If we look at induction rules and magnetic rules we see that moving charges are the source of magnetic fields. These charges once in motion can and will induce current in a coil. So you can think of the experiment as an example of creating a charge sink (ground wire) through the middle. A collector coil or receiver (bifilar coil) and an exciter to start the process and keep things flowing.
I'm thinking it doesn't need the ground connection but any mass that could be highly conductive and cooler then the surrounding ambient temp. This usually is aluminum hence the radiator buried. Burying the aluminum only gives it better ability to shed the heat once flowing. This is the perfect heat pump Tesla was working on and others said that was impossible.
