Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 357 Guests are viewing this topic.
wattsup
I had prepared a post last night but did not want to post it in the midst of all the commotion. Some of you should take a few Valiums and calm down.
My puzzlement is with the 2004 and Aq2 that must have something hidden inside the TK coil (TKc). It's too bad that @stivep and @a.king21 did not get to look straight through the TKc. When you look at the Green Box TKc, it seems like there is a center placed tube that is off-center from the end. Something has to be there because only two wire coils will not cut it at all. I would say the first winding goes inside the center at half way or another method but something is not right.
In the 2004 device where he connects the ground wire at the exit of one coil of the TK coil is simply not logical if the output is AC 60hz.
I am  trying to find a 10 foot long copper rod of 1/2" diameter to place in my back yard. But even then, just with present tests I know at 60 Hz AC if floating will have no use for that ground. So WTF is going on. The output cannot be 60Hz AC. It has to be higher frequency DC in order to have any use for the ground, unless TK is pulling our leg and using the real AC neutral on that ground wire or he is spiking it with AC hot.
Higher frequency DC can simulate AC in terms of the waveform so maybe this is why the ammeter still saw a reading although we cannot say if this is so or not from the video. These guys are just using that ammeter as if it is the answer to all questions.
Here is a question.
Can the two transistors be used to pulse each side of the TK coil. The two windings in the TK coil, one receives a positive pulse while the other receives a negative pulse. One the other side is the load with the ground wire on the negative side. This way both sides of the load go through one of the TK windings and is pulsed + and - at the same time or via a delay that is created with the 9 foot length of coax. This pulsing on and off of both sides of the load will create the maximum possible polarity change, much more then if you pulsed only one side of a coil.
Anyways, more soon when I get my ground rod.
wattsup
Сергей В.
Quote from: TheBuzz on October 23, 2012, 05:43:45 AM
Forest -
Thanks for exposing the Russian liar. The flat coil is displacement current coil. Displacement current as I am sure you know radiates from the wire at 90 degrees. What people don't notice about a pancake coil is the vortex that is created which is natures accelerator. A vortex forms because the electron has inertia, there is a vacuum difference between the surrounding mass and its center.  The electron cannot suddenly turn ninety degrees because of the law of conservation so it adopts a spiral path that we call a vortex.
Here is a coaxial version of the same bifilar coil. http://gratisenergi.se/tesla.htm
None of this has anything to do with Kapanadze or the posts I made telling people how Kapanadze worked. It just serves to bury it under useless chatter. That is why this thread has gone on for 1000 pages. That information was disclosed a few times in this thread by others.
Hope that helps clear that Russian chatter up.
Did he exposed a lier BUZZ ?? I have exposing your lies and hate - in fact your dark demonic soul. As you know hate and evil in final account kill the owner.
Tesla didn't used displacement currents in his apparatus. You can undestand this if you carefully read and try to understand all of his patents. And not only Tesla but more researchers.
If you want to expose somebody - address is American Patent Office and US Governement which are under direct control of ILLUMINATI CABAL LEVITICUS BANKERS FROM THE BEGINING OF LAST CENTURY.
What American Patent Office have done and still do ?? It's very simple. Those puppets had collected and still do, all patents which they can grab and "remade or pollished the most important contents" leaving analogisms and modified and incorrect drawings. So how many people have made successful replications according to original patent data.  I am sure NO ONE !!. I talk about Free Energy patents. For example Tesla bifilar coil. Where are original Tesla's dimesnions and recommendations for this type of coils ??
Where are original Tesla writtings ?? Maybe had burned like all historical documents of mankind past. Many people don't know that human history had been rewritten from copies of much older originals which had burned all in almost the same time. All ancient libraries have been burned almost in the same time and all originals had gone to fire and amazing all copies had survive the fire and came to us today. Miracle aa?? I know miracles don't exist. Exist knowledge and ignorance. And both are the only choice for human beings.
So everything must be checked and verified in open experiments and all data must freely circulate to all people which looking for truth. On that way of world-outlook nor one knowleage can't be Absolute. Even Great Tesla in his 80th years age said that he don't know the true nature of electricity and energy transfer. I can give you many proofs of existance of High Technology from Ancient times, the technology which is far away current technology of this planet but it's different topic and long time story.
Michael Pupin about science in Tesla's time:
By reviewing history it is understandable why some inventions are not commercialized. It is economics, not science, that is the main factor. It will be remembered that alternating current was opposed by powerful financiers in Tesla's time.
Michael Pupin, noted in his autobiography: "...captains of industry...who were afraid that they would have to scrap some of their direct current apparatus and the plants for manufacturing it, if the alternating current system received any support. A most un-American attitude...but ignorance and false notions prevailed in the early nineties, because the captains of electrical industries paid small attention to highly trained scientists."[2]
Bruce A. Perreault
http://www.nuenergy.org/alt/tesla_energy.htm
Source: Bruce A. Perreault
Radiant Energy - Unraveling Tesla's Greatest Secret
Oliver Nichelson
The Second Law Thermodynamics and Tesla's Fuelless Generator
ps. I am sick of listening MOSSAD and CIA TROLLS and spies PROPAGANDA and umbrage on NATIONAL LEVEL on this forum. This topic need Moderator steel hand which will modarate conversation on appropriate level !!
IF YOU WANT TO HAVE NAZI FORUM GO FOR IT. I WILL HAVE NO PART IN THAT !! GAME OVER !!
jbignes5
Quote from: Сергей Ð'. on October 23, 2012, 04:52:51 PM
Bruce A. Perreault
Oliver Nichelson
You know I agree with you but on one point. Yes the government has done a great many things that might be construed as treason but the people in general are not really in control. So lay the blame where it belongs. Corporations are the reason we are not represented by our governments anymore.
Lets just stop with the nationalism responses and try to stick to the topic at hand.
You got to understand that "They" or "Them" will not go quietly. Just as we shouldn't. We just need to show them how to act, we are human and the cat is out of the bag. It's taken this long to decipher it and we should have patience to let the ones who don't know to catch up. I think we are headed in the right direction.
You bring some valid points up in the arguement these are not displacement currents. I knew Tesla said that but didn't want to quote him without proof or a link. Since others don't believe you unless you have something to read about it I tend to link information a bit too much. I'm just trying to let others know why I am coming to these conclusions.
Zeitmaschine
Quote from: stivep on July 26, 2012, 02:11:49 PM
Some time ago there was a notion that TK used small neon bulbs, or string made from neon bulbs that or similar device, was to be hidden in the green box or glass table boxes
Quote from: wattsup on October 23, 2012, 04:01:38 PM
Can the two transistors be used to pulse each side of the TK coil. Two windings in the TK coil, one receives a positive pulse while the other receives a negative pulse.
Now, what if the transistors are not transistors (TO-3 package) but thyristors (TO-66 package)? And these thyristors are triggered by neon bulbs? :o
I have found an interesting video about the Tesla hairpin circuit in solid state implementation:
Solid state THP overunity?
A thyristor triggered by a neon bulb replaces here the spark gap of the original Tesla setup. The visible spark gap of the TK device is most likely for showcase anyway, so this would fit the concept perfectly.
This is just to throw one more theory into the ring ... :)
And don't forget to take the Valiums. ;D
