0 Members and 157 Guests are viewing this topic.
Сергей В.
Quote from: Zeitmaschine on August 17, 2013, 08:30:41 PM
At 22:35 TK removes the battery. From now on the device runs in self-sustaining mode as soon as the inverter is connected temporarily to the grid. The loud humming noise occurs only when the power plug of the inverter is connected to the grid in order to start the device.
At 8:36 TK starts the aquarium device with a 9V battery. The same loud humming noise occurs (and continuous for a while) although the device is not anywhere near to 50Hz mains.
What does that mean?
Привет Zeit !!  :D
Study this and use it in Barbosa patent !! You have right 100% it was the principle of Tarile Kapanadze - man who want neverendign GLORY and never ending milk and honey.
In two words Smoke and Mirrors SHOW for 20,000 bucks !! (once a year show) . But he was failed. And his team also failed.
THE LIFE IS CONTINUING  :D
The UDT - A Free-Energy Device by Paul Raymond Jensen
Quote "I have built a transformer which supplies more power to its load than is drawn from its primary source.
I named this device The Unidirectional Transformer (UDT), because the magnetic reaction of the load current does not affect the magnetic action of the primary circuit.
The UDT is composed of a parallel LC resonant primary, a split secondary, a gapped magnetic core, and a "feedback winding." Virtually the only input power needed is that used to magnetize the core.
The magnetic core I used came from a small 60 Hz commercial power transformer made of interleaved silicon steel E and I laminations. I took the core apart, separated the Es and the Is, and made one stacked E core and one stacked I core from the laminations. Then I filed down the center leg of the E core about 15 mils (0.381 mm ~ 0.4 mm) to gap the combined E-I transformer core. The resulting µ (permeability) of the core at 60 Hz was about 100.
The primary winding is wound on the center leg of the core. The two secondary windings are wound on the two outer legs of the core and are series connected. Both secondary windings have the same number of turns. The "feedback winding" is wound over the primary on the center leg and is connected in series with the secondary.
The Free-energy action of the UDT follows directly from the laws of magnetic circuits.
Consider what happens when an AC sine voltage is applied to the UDT primary. A magnetizing current flows, which can become rather high because of the low u (permeability) of the core. Fortunately, gapping the core results in a fairly constant µ (permeability) through the entire AC cycle, up to a peak H of about 720 A-T/M. This results in a constant primary inductance, which permits parallel LC resonation. Resonating the primary reduces the magnetizing power to that necessary to match I2* R losses in the primary and the hysteresis losses in the core.
Magnetizing the core results in an AC sine voltage being induced across the secondary. The magnetic coupling between the primary and the secondary is very high, but the core area within each secondary winding is only one-half that of the primary. This means that the volts/turn of the secondary will be only one-half that of the primary. For the secondary voltage to equal the primary voltage, the secondary must have two times the number of turns in the primary.
The primary also induces a voltage across the feedback coil, but the purpose and characteristics of the feedback coil will be explained later.
When a current is drawn from the output, the two secondary windings each generate a magnetomotive force (MMF) directed against the MMF of the primary. The MMF of each secondary winding "sees" a series-parallel magnetic circuit through the transformer core. One magnetic circuit, "seen" by each secondary winding, is through the center leg of the core. The other magnetic circuit "seen" by each secondary winding is through the two outer legs of the core.
The resulting magnetic flux generated by the MMFs of the two secondary windings is dependent upon the reluctances of each of the magnetic circuits. Because the center leg is gapped, it has a higher reluctance than do the outer legs. This means that less magnetic flux from the secondary will pass through the center leg than will pass through the outer legs.
In my transformer, the reluctances of the magnetic circuits through the center leg were three times higher than the reluctances of the magnetic circuits through both outer legs. This was difficult to achieve and required hours of filing, polishing and fitting of the E and I cores. The alternative was to increase the gap, which was not acceptable in my particular design because I was driving the transformer at 60 Hz and could not afford any additional loss of m in the core.
Since the reluctances of the "center leg circuits" were three times higher than the reluctances of the "outer leg circuits," one-quarter of the secondary flux passed through the center leg, while three-quarters of the secondary flux passed through both outer legs.
The magnetic flux from the two secondary windings cancels in the "outer leg circuits," leaving only one-quarter of the total flux generated by the output current to react back upon the primary. This resulted in a current gain in the secondary, relative to the primary. Lenz's law was bypassed, and Free-Energy resulted.
An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields.
Now consider the "feedback winding." It is connected in series with the secondary and is wound over the primary winding on the center leg of the core. When the core is magnetized, an induced voltage will appear across the feedback winding which will subtract from the voltage across the secondary. The purpose of the feedback winding is to cancel the remaining secondary flux passing through the center leg of the core. It effectively isolates the currents in the primary and the secondary at the cost of a reduced output voltage. The feedback winding generates a magnetic flux equal and opposite to the residual magnetic flux from the secondary when an output current is drawn.
Given the above example, where 3/4 of the secondary flux self-cancels in the "outer leg circuits," the feedback coil will only have to oppose 1/4 of the total secondary flux. Since the feedback winding has two times the core area of the secondary windings and carries the full output current, it need have only 1/4 the number of turns of each secondary winding. However, this will reduce the output voltage by 25%. Therefore, to achieve the originally desired output voltage, the total number of secondary turns must be increased by the factor 4/3; the feedback coil must then have 1/4 of the number of turns of each secondary winding in this new secondary circuit.
Given the condition in which the feedback coil perfectly cancels all the residual secondary flux through the center leg of the core, the power drawn from the output will be nearly independent of the primary input power. The primary input will be the magnetizing power and nothing more. The output power will have a negligible phase angle (due to the leakage inductance) if the m of the core (as seen by the primary) is at least 100.
In practice, it is best if the feedback winding is short a turn or two, thereby preventing series inductance in the output at the cost of a small increase in the primary input power. A parallel resonant primary circuit allows for great input power reduction while ensuring voltage stability and linear operation under varying output loads.
The UDT can be used without a resonant primary circuit for the amplification of any time-varying signal. The main flaws of the UDT are the (normally) low primary µ (permeability) and the very long secondary wire required to ensure isolation of the input from the output. A single or double stack of E-I laminations seems to provide the optimum core geometry, all factors considered. At high frequencies it becomes practical to use ferrite cores with "center leg circuit" reluctances less than their "outer leg circuit" reluctances because the volts/turn of each winding can be made very high. Conventional transformer design techniques should be used once the basic UDT topology has been determined.
I have invented and developed the UDT on my own, without benefit of any knowledge of other free-energy devices, if they exist, which utilize the basic principles of UDT operation.
Please feel free to use this information as you desire. However, I hope that no one will attempt to patent and control this type of transformer. The time on Planet Earth is 1 minutes before midnight; there is no time left to waste. Free-energy technology is not meant to be controlled by vain and greedy parasites who wish to use a gift from Mother Nature to exploit their fellow man. Free-energy technology represents a spiritual transition of the human race. Free-energy is not meant to be owned, period!!".
    UDT EQUATIONS by Paul Raymond Jensen
        Number of Turns = N
        a = V(output)/V(primary)
        V(Primary)/N(Primary) = V(feedback)/N(feedback) = V(secondary)/N(secondary)/2
        N(feedback) = [N(secondary)/2] [(R of outer circuit)/(R of outer circuit)+(R of center circuit)]
        a[N(Primary)] = [N(secondary)/2)-N(feedback)]
        R = Reluctance = l/µA
        l - is the length of the circuit in metres
        µo - is the permeability of vacuum, equal to 4 \pi \ x 10e-7 henry per metre
        µr - is the relative magnetic permeability of the material (dimensionless)
        µ - is the permeability of the material (µ = µo \µr )
        A - is the cross-sectional area of the circuit in square metres.
ps: Above principle had been realised 1994 in Russia by Andrei Melnicenko independently from Paul Raymond Jensen. Same principle used by Владимир Пантюхов in his OU flash light !! Remember the main trick is to get proper Air-Gap as was described in Jensen instructions. Number of windings calculate according to listed formulas !!
Free Energy generator  - OU Flash Light !!
http://www.youtube.com/watch?v=PoGfSDbnwbk
pps: Question for all OU folks. Does the welding transformer work at Absolute Zero temperature (and some degrees above) and why ??  Don't hurry up to answer me !! :D
Удачи !! :D
Hoppy
Carefully eyeball the small black box under the work bench at 23:11 and in particular the black cable entering it and where the white cable leaving it runs to. The black cable is I suspect feeding a grid  supply to the black box. This is why I think the noise is as a result of the inverter and grid supplies being out of phase. I think he is simply using the 'inverter' to switch the grid supply onto the lamps but the switching is none too clever as it is possible for the two supplies to come into contact.
Why would he plug an inverter into the grid? By disconnecting the battery, he renders the inverter inoperative, so I can only assume as was suggested way back, that the mains is connected directly through to the output socket of the inverter. Notice at 22:56 that his assistant throws a switch on the inverter before TK plugs into the mains, which probably isolates the inverter output 'live' connection from the output socket to prevent damage to the inverter. The whole thing is a show of smoke and mirrors!
Zeitmaschine
Quote from: Hoppy on August 18, 2013, 04:48:10 AM
In front of the whole audience? ::)
That's why the battery is replaced by the black box. It is a 12V DC power supply (transformer, diode bridge, filter capacitor) to power the inverter. The black box DC power supply is powered by the output of the device. The device is powered by the inverter. It is a self-sustaining loop once started by connecting the inverter momentarily to the grid.
Hoppy
Quote from: Zeitmaschine on August 18, 2013, 07:56:10 AM
Yes, this is where magicians work best.  ;D
Then why are there three cables into the black box 12V PSU? A thin twin flex cable to the mains plug held by TK (which i think you are saying initially supplies mains to the 12V DC PSU), the white cable running over towards the lamp array and the black cable into the black box from who knows where. If the thin twin flex is powering the 12V PSU, why would the cable be run up through the workbench and then drop underneath to the socket strip, when it could just be taken underneath the workbench directly to the socket strip?
magpwr
Hi Grumage,
I have done a quick experiment today using the HV transformer which is connected to a 5watt 220volt bulb and got better result by connecting hot wire with 2mm spark gap leading to bulb.
This experiment was done out of sheer curiosity  if a 220v bulb would work via spark gap.Battery consumption via watt meter is 8 watt using pulse width below 35% to get optimal light output.
I have bought a 60watt bulb as well but it has got no Ohm reading at all.I had to throw that away since it's not feasible for me to go back to the hardware store just to swap 80cents bulb.
Since i have not received my 40KV diodes and 50KV capacitors hence i am unable to conduct the experiment with Avramenko plug with Caduceus coil assembly.
Using Earth connection touching either to negative or positive supply or touching HV transformer body or it's ground pin produced no notable effect base on current setup shown in photo.
