0 Members and 205 Guests are viewing this topic.
T-1000
Quote from: magpwr on August 18, 2013, 12:12:58 AM
Hi T-1000,
I find that interview with Sweet's equipment creator provides even more details.Like Sweet putting magnet slab into toaster or oven before starting to condition the magnet.
Walter Rosenthal comments on Sweet device
From this above video once ended lead me to actual Sweet magnet conditioning device replication done by a youtube user.
http://www.youtube.com/watch?v=nFarS-liuBY
He used 2 instrument to verify the pole of the magnet after conditioning 1)one is a magnetic viewing sheet 2)Electronic pole tester to show north or south on the surface of magnet.
Now there is a problem i can't find any online sales of this magnet besides China or India company which produce Ferrite-Barium magnet.
I have actually purchased 'Barium Titanate" from ebay around 2 years ago after reading some article.Please have a look at the video below about this.Currently i'm searching for it high and low in my drawers. ???   http://www.youtube.com/watch?v=lOC9I_9VyMc  or http://www.youtube.com/watch?v=pZM3kwQWHko
In worst case if that magnet can't be found.I'm not sure if your Caduceus coil with pickup can be fitted into the driver unit for Kapanadze device for Grumage since it have the ringing upwards features. ;)
Well, the magnetic poles fancy arrangement imprinting is only part of what was needed there. The special case is when you imprint frequencies into magnets and they keep doing oscillations after power is switched off. This is where was my question - how to do it? With NMR it is neutron emission/radiation but on lower levels there should be just flipping atoms which effectively make solid state moving magnetic fields..
With AV plug + caduceus coil it is special case too because you need to pick up magnetic field from it for induction when this coil is one plate of capacitor so it is not same as TK was doing.
magpwr
Quote from: T-1000 on August 18, 2013, 10:47:38 AM
Hi T-1000,
This is just my theory the blade was placed precisely in the middle of the magnet which interact with the "existing magnetic bubbles" within the Barium Ferrite (Grade 8  ) magnet.
This cause it to flip-flop(flipping) all the way.If that blade was not placed on magnet then there is no interference to the magnetic bubble.The bubble will stay still.
It merely take tiny micro-watt of power to move the bubble away before it return back to original position.This sudden shift in magnetic flux is what create ou on the coil(believe to be caduceus coil) beneath the bubble.There is another magnet with magnetic bubble below the coil as well.
The self flipping part looks confusing to many.Merely need to isolate this thought for now to simplify understanding.
T-1000
Quote from: magpwr on August 18, 2013, 11:46:34 AM
Hi T-1000,
The blade won't wobble 24 hours+ on standart magnet. It is common behavior.. ;)
This was exactly Floyd Sweet secret and until it gets found out once again how to make this behavior on magnet all replications on Floyd Sweet device will fail.
The clue might be there with magnetic switching - http://www.youtube.com/watch?v=-u3fOwkiM7U
forest
I can't believe you are all still running around in circle  :-\
magpwr
Quote from: T-1000 on August 18, 2013, 11:59:34 AM
Hi T-1000,
If you search on creating bubble within a magnet by any scientist.You will get alot of garbage result with no answer.
Sweet was the only man whom knew how to create this bubbles within the magnet.His so called partner base on link i have provided earlier in this forum whom created the equipment for sweets did hint something about sweet creating a circular bilfilar coil on top and below for conditioning that magnet.I think this to force the creation of bubble within the magnet slab.
The part why sweet put magnet in oven is confusing for me before commencing conditioning.
The youtube link which a guy replicated sweet conditioning steps.Although he replicated the device but he failed to create a circular bifilar coil top and below of magnet.Hence when he used a magnetic viewer we merely see it's one huge bubble on magnet.I don't think that is useful.
