0 Members and 372 Guests are viewing this topic.
captainkt
@alejandroguille, over 1400 pages over 21,000 posts and still no modus operandi of Kapanadze device. So no I do not think anyone got lucky.
Keith
alejandroguille
Quote from: captainkt on April 16, 2014, 03:58:16 AM
Keith
We may be close to discovering everything, and this was created to mislead.
We should return to the beginning.
havuhung
Keith
Hi All,
I'm wondering are we missing something to recreate Kapanadze device?
alejandroguille
Quote from: havuhung on April 16, 2014, 09:07:36 AM
Hi All,
There is no definite design, there are over 10 types designs.
No one showed clear replication ...
I'm wrong?
elementSix
Quote from: alejandroguille on April 16, 2014, 08:47:05 AM
I presume you have not read this forum for long?  I posted exactly how it works.  The only reason I am still posting circuits that might be possible controlling devices is because I use a cam with contacts for creating the impulse train that creates the static type of potential. As it was just pointed out with the relay contact, they burn up and mine are brass and suck for long use.  But I suck with circuits, I am more of a builder than an E.E..  I had help building the TK energy conversion device, but that help has taken off and I have had shit for help from those who post on here.  Yes, I know that most who post here are Feds.  But if some one else would at least try to make a little effort to create this conversion device it would help me out and maybe some one with the Circuit building know how can help us make the "Resonator".  Which is just a PWM that varies the transistor driven by the square waves pulse width and frequency that creates the Impulse.  EFNMR has been found that it can now be created by just using pulsed DC.  Now the Earth provides the low strength homogenous Magnetic field and the impulse turns the nucli up from the low energy state and in doing so, releases energy.  But there is a relaxation time that is required which is needed for the Nucli to return to its natural position with the Earths Field.  It is a very short time and it's called the T1 or T2 relaxation time.  This also varies with the metal that is being used.  When they used HF AC to spin the Nucli, the larger the magnetic field used, the higher the frequency that is needed to spin up the Nucli.  So this is why the Impulse timing, resistance, capacitance and also as equally important is the input voltage and current.  It too must find its resonant point within the circuit.  The wave length of the Impulse can be change the output.  Shorter waves are best, and I am pretty sure that it must be a damped wave.  I try to tell you guys everything I know, but I am not an expert.  VisaVe, why I need help.  I hope you can figure it out.  I am not on here much anymore.  But will drop in and post when I can.  Good Luck..
