0 Members and 357 Guests are viewing this topic.
a.king21
Quote from: zcsaba77 on June 30, 2014, 02:45:32 AM
Hi MenofFather
If I good understood You (and Wesley) if work like AC, load will consume electrons and inertia electrons once will come from ground and once will come from air, vacume, or where from?
regards zcsaba77
Here's your answer.
http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=GB&NR=191417811A&KC=A&FT=D&ND=4&date=19150513&DB=EPODOC&locale=en_gb
zcsaba77
Quote from: MenofFather on June 30, 2014, 03:12:31 AM
I suggest, that energy giung from ground and then going to load, and going to ground less energy, than going from ground (because is special pick up coil). Also if is hight voltage, then two coil is like capasitor and if betwenn them air gap, then maybe go new electrons, energy, from air. :)
Someone measure the current on the scope between coil and real ground? how its look? or try put paralel ampmeter with diode, but connect diodes connnect opposite with ampmeters, one will measure comming electrons to coils, second will measure outgoing electrons from coils!
MenofFather
I meashure. I made tesla coil and put 53 wats 220 V halogen lamp betwen grounding wire and buttom end of secondary coil. Then tune to resonance tesla coil. Lamp shine bright. Then I chek with osciloscope signal on lamp and be sine wave with Tesla coil frenquency.
zcsaba77
Quote from: a.king21 on June 30, 2014, 06:52:39 AM
Here's your answer.
some page was unavaible in error server, but watch the old drawings this one look like tesla switch circuit,
BUT is NOT mentioned direction electron flow between ground and tesla (or whatever named) coil (or maybe I somewhere missed)
