0 Members and 473 Guests are viewing this topic.
baroutologos
Hey dole,
can you be more specific about the circuit posted? For example, HV source is a nst? of what power?
The HV possitive lead is connected solely to a transformer winding? Does the SG even works there?
The more detail you add the better.
forest
dole posted important circuit, we have to find the bare minimum to understand
dole
Hi,
I did some brain work again, (verified in earlier tests). SG is not needed there,
there is adjustable condenser there, SG is just to feed an HV current in to a resonator,
as higher as better. We may see now glint of the famous MT.
@bart
Yes there is tiny SG there, but on the wrong place, use condenser there;
further the external HV coil should be probably wound inside the output coil.
Word self-sustain appears slowly out.
But do not hurry, we or someone will achieve and republish this just in time.
d.
FreeEnergyInfo
Quote from: sartravut on August 05, 2010, 06:47:10 AM
Thank you for the translation.  Also, welcome to the group.
Garbage !!!! ??? ??? ??? ??? :-[ :-[ :-[
***Edited by Moderator to remove spam links***
