0 Members and 164 Guests are viewing this topic.
sigma16
Quote from: iceweller on November 26, 2010, 03:11:29 PM
  Sigma, I also think that Tariel followed Tesla's concepts and patents as indicated above and I think Oliver's research can help a lot in getting more insight on the operation of the device(s) and helping others follow a constructive path.
I think the homopolar generator is related in some respects, but the rest doesn't appear to be, other than the fact that high voltage pulses interact with the medium.
iceweller
Quote from: sigma16 on November 26, 2010, 03:37:11 PM
   The homopolar generator is of course highly interesting but the self-acting machine is just as interesting because they both work with the same concept - that is maintaining an oscillatory action with a minimum effort (power) to keep the "sink" (sweet spot) thus the current flowing:
The earth has a charge of 90,000 coulombs. With a potential of 360,000 volts, the earth constitutes a capacitor of .25 farads (farads = coulombs/volts)(18). If the formula for calculating the energy stored in a capacitor (E = 1/2CV2) is applied to the earth, it turns out that the ambient medium contains 1.6 x 1011 joules or 4.5 megawatt-hours of electrical energy.
In order to tap this energy storehouse Tesla had to accomplish two things - make a "cold sink" in the ambient energy and devise a way of making the "sink" self-pumping. Explaining how this process might have worked requires, again, speculation.
Such a "sink" would have to be at a lower energy state than the surrounding medium and, for the energy to continually flow into it, the "sink" would have to maintain the lower energy state while meeting the power requirements of the load attached to it. Electrical energy, watt-seconds, is a product of volts x amps x seconds. Because the period of oscillation does not change, either voltage or current has to be the variable in the coil's energy equation.
In that the double wound coil maximizes the voltage difference between its turns, it is probable that it is the current that is minimized to produce a low energy state in the coil. For the coil to be initially "empty" and at low energy would mean it operated at high voltage with a small amount of charge.
The coil, then, would be set into oscillation at its resonant frequency by an external power source. During a portion of its cycle the coil will appear to the earth's electric field as one plate of a capacitor. As the voltage across the coil increases, the amount of charge it can "sink" from the earth's higher energy field will increase.
The energy taken into the coil - through the "small opening" which appears to be the atomic structure of the conductor according to the physics of Tesla's time - is "condensed" into positive and negative components of current, a lower energy state relative to the originating field.
The current is equivalent to the water converted to gases in Tesla's description of the self-acting engine. The current would "escape" from the "sink" into whatever load was connected across the coil. The movement of current into the load would produce a strong magnetic field (the stated intention of the patent) which, when it collapsed, would, again, produce a high potential, low charge "sink" to couple with the earth's electric field.
Because the inflowing energy performs a double function similar to the unipolar generator, supplying current to the load and aiding the pumping function, the system's energy expenditure in moving charge is low, allowing the system to gain more energy from the medium than it expends in its operation. The coil needs no extra energy from an outside source to pump the energy it has extracted.
Energy would come directly from the sun.
A more modern view of such a device, should it prove to operate in this theoretical manner, would be to describe it as a self-oscillating capacitive system. Once the device is set into oscillation, very little power is expended in driving the load. Because it is an electrostatic oscillating system, only a small amount of charge moves through the load per cycle, that is, the coulomb per seconds = amps are low. If the charge is used at a low rate, the energy stored in the capacitive system will be turned into heat at a slow rate enabling the oscillations to continue for a long period of time.
   So TK's coil is kept oscillating at it's sweet spot and the counter wound coils reduce the current while at the same time generate the pulses necessary to keep the "sink" in action. Now the question is: is this oscillating frequency connected to the length of the coil wire or just length of coil setup or independant and must resonate at some specific frequency for this to occur as it seems that there are specific ranges (around 500KHz) reported.  It appears from the video that the device doesn't need to be adjusted based on different loads (it is possible that there is some feedback/autoregulating circuit inside) or simply that the device can deliver up to 5KW without adjustments which I believe be more the case as the load shouldn't really affect the "sink".
sigma16
baroutologos
Energia
this was what i have told earlier, no one listened, check my website on my setup which no matters how long the wires are, resonance frequency is allways same  exactly 500.0khz, 500 khz is the point wher my bulb shines the best, no other freq is better than this while other coil confiurations are allways different, hope this helps
What are your experiments on this? Your web site link?
energia9
Quote from: baroutologos on November 27, 2010, 07:15:50 AM
Quote:
    Energia
The schema is here a few pages back, its not the Prentice patents schema, it is just interresting how resonance frequecny is alllways the same at only this kind of setup.   http://feny555.blogspot.com/
