0 Members and 248 Guests are viewing this topic.
xenomorphlabs
While it is necessary to avoid, the experimental effect of a vaporizing ferrite core sounds good.
He seems to have managed to hypersaturate it.
Ferrite is a classname for several materials containing either Barium or Strontium, some might work better others might not work at all for a particular set-up.
T-1000 has a good link, i think the effect seems to be connected to electron spin converting into magnetic oscillation.
Cap-Z-ro
If Barium and Strontium, 2 toxins found in chemtrails, are also found in ferrite, would the destruction of these ferrite core's in the process not be detrimental to ones health ?
Regards...
T-1000
Quote from: Cap-Z-ro on October 28, 2011, 12:45:44 AM
Regards...
From http://en.wikipedia.org/wiki/Ferrite_(magnet)#Soft_ferrites
The most common soft ferrites are:
Manganese-zinc ferrite (MnZn, with the formula MnaZn(1-a)Fe2O4). MnZn have higher permeability and saturation induction than NiZn.
Nickel-zinc ferrite (NiZn, with the formula NiaZn(1-a)Fe2O4). NiZn ferrites exhibit higher resistivity than MnZn, and are therefore more suitable for frequencies above 1 MHz.
Shokac
Quote from: dllabarre on October 27, 2011, 08:18:24 PM
Wesley, T-1000, Aidas
I thought this team was duplicating Tariels device?
Tariel didn't use ferrite core in his coil on the Green Box device and he got 22amps on the ground wire going to the bulbs (load).
I don't understand?  ???
DonL
This is replica of SR Device
