Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 216 Guests are viewing this topic.
zen_guru
guys, let me remember you that tariel's device is not based on magnetic - electromagnetic induction of the core. is not what we have learned from books. get the ferrite out of your heads. you'll obtain nothing, or almost nothing, like sr does. is no big deal to light a 100W light bulb. you can do it in 1000 ways. you can do it near a big radio antenna, you can do it using a 9V battery, you can even do it with a 3V cell battery. we are talking about big power here. KAPANADZE IS NOT USING FERRITE IN HIS SETUP!
if the primary and secondary coils are in resonance you can achieve high voltage, high amperage, high frequency in the secondary. than you can play whit those and get what you need. 220V 50Hz, and so on. the real gain is in coils! air core coils!
at high voltage and frequency (above 20kHz), the electrons begin to spin outside the primary coil. the secondary coil replicates this effect in each turn and multiplies it because the number of turns. then you can move those free electrons using the ground and the capacitor. convert the output in DC then in AC as you need 200 - 50 or 120 - 60. you can feed back the HV HF generator using just 0,01% of what this system produces.
when you create a disorder somewhere, the nature tries to balance that disorder, making a new order. using the force of nature of balancing things, you can convert the energy that you need.
indeed, the major problem is to keep the frequency after you put the load. "keep the resonance". i think this is the major work of tariel. i think he stabilizes the freq using the second spark gap.
i would like to have more money to experiment all these, but i'm limited to small experiments.
energia9, when you'll replicate your own experiment, try to find a way to keep that resonance! your bulb will stay lit forever.
forest
Quote from: zen_guru on November 19, 2010, 03:25:07 AM
hmm...you are talking like Don Smith  ;D
Looking at his teaching I feel that Tariel is using bifilar coil capacitance to store energy and discharge via spark gap at lower rate. Isn't the capacitor the solution to keep resonance ?
If is it charged from one side and discharged at second at slower rate would that be decoupling eliminating lens law ?
zen_guru
forest, i assure you i'm not don smith! :)
yes, i think the capacitor discharge is keeping the resonance. and "slower rate" discharge is proportional somehow with the load. less load, faster discharge.
tariel found something more than don smith. he tells that don smith and tesla inspired him. i'm sure that tariel didn't want to find free energy. he just wanted to consume less energy using the frequency in his advantage. i'm sure you know that few decade ago, some people used a buried metal object and a faze from the electrical counter to "consume less". i think our architect just said: i'm gonna give that a try. this happen in underdeveloped countries like romania (where i live), bulgaria, georgia, albania, montenegro, and so on. he found something and made us not to sleep at night. :) all the s*** can't be so complicated, but is something that we all miss out.
anyway, the ferrite has nothing to do with this setup. this setup uses HF, and HF is bad for ferrite and for our time.
http://www.youtube.com/watch?v=Qvn7r2Nm-b4&NR=1
nievesoliveras
On this link there is a Kapanadze Replication. It is in russian I think.
Did this guy attained the right Kapanadze Circuit?
http://www.youtube.com/watch?v=0xz1GS6WOrI&feature=player_embedded
Jesus
energia9
Quote from: zen_guru on November 19, 2010, 06:08:53 AM
Zenguru Completely right, My tests show that ferrite Deteriorates high frequency apparatus,  even at low voltage, but in high voltage, its completely useless, But For the power output you need ferrite,and thats a different transformer which regulates current like the one which is counter wound and its center tapped for the wanted voltage. also it is the device known as magnetic amplifier which draws more current in the transformer with the help of a low voltage input which makes ferrite a magnet , the design is exactly the center tapped coil one.
   I have done a simple experiment with a spark gap and a grounding the frequency was 32 khz from a dissasembled plasma globe, the bulb shined ok  but when i hooked a 30cm x 15 cm steel plate lying on ground the bulb shined 2 x times when connected to ground through spark gap ,  But if Metal plate buried under ground even better, but metal plate must in earth just like it would lie on the ground, if metal plate is turned to its edge lamp goes away.  the water pipe which goes under the whole city was not enough good, but my little plate did 2 x better than that kind of grounding,   (No it not acted as an antenna, the closer i took the plate to the transformer the more the bulb dimmed.)
this is to point to teslas magnifier also , he could just put metal rods in the ground  which is not good!    very good grounding must be taken to account when trying to make a working device.
Also at some of my transformers i the more pressure i applied to the contact the more the light bulb were lit, i cant explain this, but will experiment more to make a full report.
One more thing to take account,   before i disconnected my freq gen from transformer, i loaded my capacitor to full power then discharged it and then loaded it again then disconnected source, lamp were still lit,
