Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 357 Guests are viewing this topic.
jbignes5
Quote from: cheappower2012 on May 27, 2012, 09:35:40 AM
Get down to earth guys,a static potential difference,as in an  earth charge is a totally different
thing from an ac current coming from the earth.You could have a very, very small ac current that's  possible
but a huge ac current like 22 amps is not possible,In the case of TK's video's its an error measurement
caused by the type of clamp amp meter used,look at what I previously posted.
A static discharge and current flow ,direct current,is not an ac current,in the TK's
video's its mostlikely a trick to fake out anyone looking at the video,or  a remote possibility that's its an error on TK's part.
Really so different huh? Collect discharge into normal coil and you will get an AC response. Rectify it and walla dc again. Tesla knew this and utilized it to fill a cap and dump it into any load.
Pictures courtesy of:  http://www.tfcbooks.com/tesla/1919-05-00.htm
The text is pretty good as well...
Shokac
read again one old post:
Quote from: teofiliuss
Now Tariel judged against Turks because they have electronical version contract, but
Turks tried to break it (tried to steal the technology?). After the trials, he will have the opportunity to enter into business contracts for this electronical version of the device.
Also at that meeting he said further details of their installation. This is two Tesla transformers. They are connected through a wire from the top. Between them must be a resonance. First transformer works via spark on 100 kHz and higher.
Second - is a power transformer. In the first transformer we have small capacitor on primary coil for the high-frequency discharge. On secondary coil (power transformer) we have large capacitor for decrease our high frequency. In the output of the Turk device are powerful diodes. They fix output energy. Next step - it passes through a capacitor and then formed 50 Hz.
I guess that between first and second Tesla's transformers take place a capacitor.
Spark is used for resonanse selftunning. According to Tariel - many people achieve in their experiments Free Energy, but they don't understand how to reduce frequency and voltage.
This method and some another moments (which while hiding) - have a very simple solution. Those who want to succeed it - must think simple and do it simple too.
Tariel also said that he already has sparkless version of kapagen. It is a fully electronic solution. I think that Kapanadze use thyristor for this purpose.
We talked about vacuum tubes too. He said that this is a best solution! But sadly vacuum tubes can live in such device not more than ~1000 hrs.
Giya (Kapa's assistant) suggest that the best way for replicators - begin from high voltage as the input power (against 12V akkum. or battery) for start process.
It must be 220V or even more.
Tariel said that the resonance between two transformers "shakes" the aether and it give more energy. Ferrite core prevents the process and therefore does not apply at his device.
That's all what I know right now about it.
jbignes5
Quote from: Shokac on May 27, 2012, 11:01:03 AM
Hmm. Excellent...
Might I add some understanding to his text.
"We talked about vacuum tubes too. He said that this is a best solution! But sadly vacuum tubes can live in such device not more than ~1000 hrs."
"Tariel also said that he already has sparkless version of kapagen. It is a fully electronic solution. I think that Kapanadze use thyristor for this purpose."
MAGAMP
"Tariel said that the resonance between two transformers "shakes" the aether and it give more energy. Ferrite core prevents the process and therefore does not apply at his device."
I absolutely agree here if you take into account what charges are as I explained earlier. This shaking is a longitudinal one and helps to unravel the many lines in the charges interior that are loosely bound and forever moving and adds them to the lines of a higher potential source. This makes the network shorter in a sense of time traveled and less time of propagation if one could measure that short of time. The main connective lines seem to be stretched in fact. we could use the charge theory of mine to explain our world as well. The direction is always counter posing like a bifilar coil. It's capacity is immense.
Going into space you start to understand the vast phenomena's going on across that space. Gravity is one effect that seems to be absent for the most part. This is because of the networks sparse very thick network connectors and the distance between them. Outer space is after all stretched and a Vacuum forms. All energy travels along these networks and this includes light. Our perspective is that it looks 3d spatially but it is not in reality. The energy has a main path and only follows that path in general. Matter dictates this as well. It could also be said that light doesn't travel on those paths? This could very well explain why light is not hindered by the network. The light has little to loose in that sense since matter would have to be present to slow down it's speed. I'm still on the fence about the light issue..
Here is something to look at... http://www.youtube.com/watch?v=JIIhgHTEoM0&feature=related
Hmm: http://www.youtube.com/watch?feature=endscreen&NR=1&v=iJsVSMQqCOM
Somethings about electric fields and "magnetic"
http://www.youtube.com/watch?v=n4Hj_bUDmw4&feature=related
anandml
Thanks  Shokac for your valuable information......
woopy
Hi all
some update for the eventually interested
good luck at all :)
Laurent
http://youtu.be/7g9DPL_QU2g
