Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 62 Guests are viewing this topic.
Farmhand
The reason Bedini (and others) can light neons from the top of the battery and the floor
is because of a combination of spilled or leaked electrolyte, sulfated batteries and Voltage Spikes.
Not because of radiant energy. I can do it too, but I don't fool people with the effect. Those are effects of conduction.
The electrolyte is spilled or comes out of the battery in a spray from the bubbling electrolyte, the electrolyte even gets forced out of the caps.
I don't have a sulfated battery with electrolyte on it to demonstrate, but I have a good one that needs cleaning, if the electrolyte is covering
the top of the battery between cells then a voltage can be read from the casing, this drains the battery parasitically. I might be able to
demonstrate the neons and can definitely demonstrate the voltage reading on the outside of the battery casing. Anyone that calls that radiant
energy is mad, misleading or very unobservant.
Radiant energy this and radiant energy that, what a load of bull. Bedini's stuff under unity.
a.king21, You say it is over unity he gives all the info, demonstrate it and prove it. Other wise it is all talk.
The voltage readings on the battery case and the floor are due to conduction of the Voltage spikes through the leaked electrolyte.
Cheers
P.S. It is these little tricks that the unscrupulous money Guru's use to WoW and fool people into giving them money.
Anyone who tries to shed light on the matters is attacked as a troll or Oil company shill, hahahhahha. ridiculous .
The way to clean the leaked electrolyte off the battery is with baking soda and water and a scrubbing brush.
It's called battery maintenance.
Hoppy
Quote from: a.king21 on November 09, 2012, 07:09:44 PM
The problem with looping radiant energy is that it leaks all over the place.
TK uses extensive shielding to prevent radiant energy loss.
He uses polystyrene, polythene, plexiglass, epoxy resin,
braid, HV cable and finally a very wet earth.
So if you want to loop a Bedini - start with extensive anti-static shielding as outlined
above.
And I am trying to help wattsup.
Every single solid state TK build contains extensive electrostatic shielding.
And don't forget HV cable in the coils.(Or soak them in oil).
Why do you think TK would cover a solder joint with epoxy resin?
You also can't loop direct, because the circuit sees a direct short.
So you have to go via HV coil to coil induction, as in TK's patents. (impedence matched).
If you think it's pub talk, then maybe I should stop posting.
Bedini uses plexiglass as its easy to work, aesthetically pleasing and importantly, non magnetic. He uses resin mainly for security against copying as is used in the electronics industry. Neither offer any barrier to the leakage of radiant energy to my knowledge. Also, since when did the materials you mention become anti-static and where does he use polystyrene and polythene? I have never heard your explanation for the use of these materials mentioned anywhere in the plethora of forum posts and other writings I have read on Bedini Tech. Can you offer a link to the source of this information as I'm sure others would be very interested in seeing this confirmed.
Another point you raised was about how containment of radiant leakage increases COP. TK demonstrates self-runners in his videos, Bedini does not. Bedini has never claimed any of his devices self-run, just that they can have a high COP.
PS. We are getting close to 1000 pages!
a.king21
forest
Quote from: a.king21 on November 10, 2012, 08:39:00 AM
Farmhand:  Voltage spikes= radiant energy.
Please use a better scope and the max resolution. What do you see , still spike ?  ::)
a.king21
Wattsup:  There is also a conditioning process to consider.
It took Dave Lawton a month of trying before he replicated Stanley Meyer.
The reason is that the capacitors acquire a nano coating which takes time to appear.
TK sometimes takes several days to get his device to work.
So once you get the pulsing effect, you have to leave the device on for a minimum of 12 hours.
