Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
cheappower2012
Zeitmaschine
In the past there have been many, mix frequencies ,output equals overunity,in each
case ,it was a measurement error.This applies to the Westly device
unless a device is looped you have nothing but hot air.When you look at things remember
TK looks like an old Santa Clause in a junk work shop,some members here do a projection of
abilities,
if they have a degree in physics,they believe in an exotic theory,they project there abilities
on to TK.Keep in mind that TK has limitations when you do your experiments.
This projection is illogical,this leads to some silly theories,this same thing happened with
the tpu thread.With the recent crap of verpies=wasabi my feeling is jjbignes5 =verpies=wasabi=Hoppy
possibly a few more,trust no one.Weither this is to get attention or distract,I don't know,
If the secret
of TK's device were found it would cause a world wide economic system collapse.On that waveform
you posted,if its the noise that happened when the inverter was plugged into mains,I think thats
a small isolation transformer in the inverter,that can't source
the current to power the device so gets loaded down,not a function of the device,the inverter that TK uses is
strange,however it may serve a purpose
or it would not have that built in.When the device is powered by the inverter,thru the battery
its quiet.Another aspect is what size ratings are the lights used in the demo's,1,000 watts
seems a lot for
a person in there home,I would guess 100 watts,there should be a few members here that live
in areas where bulbs like that are used.The light's rating is important since it determines the output of the device in the demo's.
TK's device is not a Tesla invention.
Grumage
Quote from: verpies on February 09, 2013, 03:12:22 PM
I'm not replying to this because your transformer does not appear to be a parametric transformer.  I base my assessment on your experimental results which show mutual induction even with low power levels - parametric transformers exhibit zero mutual inductance between the primary and secondary windings.
This is not a matter of "loose coupling", there is a whole chapter that describes various methods of eliminating this mutual induction. See page 200 in chapter 4 of this document.
He is describing one of the proven methods to avoid mutual inductance.  Your joining of the two toroids by the shorted center winding, is completely different.  It makes the orthogonality of the cores irrelevant.
Your scope probe has an internal capacitance and the unloaded secondary winding forms an LC circuit with it, leading to a "resonant voltage raise".  I bet that if you load the secondary with a 1k resistor, then the increased voltage will disappear.
Many thanks for your input. However having read your post I put an even greater load resistor than you suggested 14ohm 1/4 watt carbon directly across the output. Yes I did see a drop but there was still a greater voltage seen at the output. I know this is basic stuff but what is the explanation?
elementSix
Quote from: Grumage on February 09, 2013, 04:28:04 PM
Thanks a lot for your Input, GRUMAGE..  I verified your findings with the Strange Russian Transformer...  I used copper ribbon and made a tube with it, but I left a small gap, long ways.  So that the tube wasn't fully a tube.  It sings like a MoFo.  Around1300Khz, It got so loud that it hurt my ears.  I used a 5 volt output from my Function Gen. and hooked up a long wire through the copper tube that was inside of the ferrit rings and hooked the wire to a LED.  It only lite up in the KHz range.  The function gen. can only lite the LED up just a little bit when I hook it up directly to the GEneerator.  I am going to try your version of the Peizoelectric transformer tonight.  But I appreciate your input on this subject and your videos.
Hoppy
Quote from: cheappower2012 on February 09, 2013, 04:23:15 PM
Where do you fit into your equation?
verpies
That is unusual - I will think about it some more.
Of course voltage alone is not power nor energy.  Most likely you'll need to measure current & voltage simultaneously by your scope to resolve this.
