Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 219 Guests are viewing this topic.
Zeitmaschine
»Plasma is a gaseous mixture of free electrons and ions that have a high mean kinetic energy. The charge carriers influence each other due to their inherent charges and energies, and are also influenced by external fields. The physical properties of plasmas are notably different from that of other fluids that they have been classified as the fourth state of matter.« IONIZATION OF AIR BY CORONA DISCHARGE
If we have ionized air due to high voltage, we have free electrons. Those electrons are not bound in a metallic wire. Then what could happen if we expose them to a magnetic field? Could this magnetic field accelerate or decelerate the electrons? If yes, what could this mean regarding the charge that the electron carries? If it means something, would this also be true for the free ions?
When an electrons moves with a certain velocity and has a certain negative charge, what happens to its charge when we slow that electron down (by means of a magnetic field)? Could this change its charge somehow from our point of view because for the electron the time runs slower or faster due to the acceleration or the deceleration of its velocity?
I have no idea, hence we should keep experimenting with ionization and magnetic fields. :(
NickZ
  If you want to really know what going on, read about Tesla's ideas and tests concerning these things, not what our current science has to say about it. I've posted some of his ideas, already. As our best scientists of today don't know how to make the "amplification effect", nor know how to make any circuit self run. Nor even believe that it is possible.  Although I doubt that they have not caught on by now. They just continue to hold these things a secret for as long as possible, at our expense.
  Free Energy, is not allowed, in our current state of affairs.
   Just look at how solar panels are limited by our governments to about 18%. Why is that?
  Do you think that the ISS solar panels are only 18%?
  Tesla's most important finds, and his most important notes, are still not being disclosed to the public at large, as some of them can be used for weather control, and weapons of destruction, etz... such as with Harpp, or like those huge Russian Tesla coil instalations, All based on Tesla's inventions and ideas.
Void
Quote from: NickZ on March 29, 2016, 10:23:08 AM
Hi Nick. You actually didn't post some of Tesla ideas. You posted what some guy wrote about Tesla.
There is a big difference. :) People are constantly making all sorts of claims about Tesla and putting words
into Tesla's mouth which he didn't actually say. If you want to know what Tesla actually thought and said
about something, you have to look at Tesla's own writings and his speech transcripts or articles in which there
are direct quotes from Tesla.
There is so much nonsense written about Tesla that the only way to know if something was really said by
Tesla is if you can find it stated in one of Tesla's own writings or in his speech transcripts or in articles that
contain direct quotes of Tesla. Anything that you read that is written by someone else about Tesla that doesn't
provide exact references to where Tesla supposedly stated what they are claiming Tesla stated should be very
suspect IMO. :) For example, if you can find me a direct reference where Tesla talked about aether streams in
regards to Tesla coils and spark gaps, I would be interested to see it. What someone claimed about Tesla in
an article or book could potentially be quite far from the truth, and it often is. :)
Zeitmaschine
What about something practical for a change? Back to the basics:
We connect a transformer (or a coil) to 220V/50Hz (grid or inverter), then we connect a capacitor in parallel to it.
So, what would be the best method to adjust the capacitance to get resonance at 50Hz?
Neither the reactance coil nor the 50Hz source can be adjusted. What remains to be adjusted is the capacitance, but unfortunately a capacitor of a few µF is not steplessly adjustable. (Changing the frequency continuously is easy though)
Hence, how to get the correct resonance frequency the easiest way? Perhaps putting an incandescent light bulb between the LC circuit and the supply, and then adjusting the capacitance for minimal brightness?
Or vice versa: Connecting the incandescent light bulb, the coil and the capacitor in series and then adjusting for maximum brightness?
How can we get free energy if we can't even get a simple resonance to work correctly? ::)
Interesting by the way: A parallel LC circuit at resonance acts essentially like an open circuit (link above). Does that mean the coil/transformer generates a magnetic field at resonance without any energy consumption?
forest
Quote from: Zeitmaschine on March 29, 2016, 03:45:23 PM
Very important question ! GOOD! I believe it is so, because electrons are just small magnets. Here is the problem : Lenz law.
