Hydrogen from urine the new path...
Started by infringer, July 05, 2009, 03:28:46 PM
infringer
It appears that the bond in urea is less strong then in water.
4 hydrogen atoms are within urea vs water.
It takes 1.23v to get hydrogen from water.
It only takes 0.37v to get hydrogen from urine.
Leftover waste is useful for agriculture amongst other things.
This is excellent tech read more at the link below.
http://www.physorg.com/news165836803.html
LET THE HYDROGEN TESTING BEGIN!!!
It is cheap and effective now with chicken feathers in the tank it will allow for a higher energy output!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
utilitarian
Quote from: infringer on July 05, 2009, 03:28:46 PM
I am not an expert in electricity, but I believe that volts is not an accurate measure of the amount of current.
infringer
That is correct I really wish they would have mentioned the amount of current used for the application indeed unfortunately I did not recall reading that information but I will see if I can dig up the current specs some how or another.
-infringer-
CrazyEwok
You will discover that the initial voltage drop from using your urine is because of its increased conductivity... one of the many problems with this is that your urine has a sulfur content (diet dependant) and this will produce a nasty gas with your O2...
The unfortunate thing is in order to overcome the resistance of the water you need X Voltage. You can lower the voltage by shrinking the gap between the reactive surfaces or by decreasing the waters resistance with additives...
sm0ky2
yeah,.. i would think about using salt or some other electrolyte before we all start pissing in our electrolyzers......
