Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@JD and SmOky2
The Stainless and carbon looks like the way to proceed, I find that very interresting, at least the electrodes should not suffer corrosion problems and the higher output also,,,, big hummm here, could be another KEY in the puzzle, good work.
I also have noticed the ups and downs of voltages with my series cells setup, if it is dry, the voltage is lower, when I add just a little moisture, (20cc to each cell) the voltage rises, then returns to the low reading as the water evaporates. :)
A few hours ago I used a rat tailed round file to deburr the top and bottom of the 63 copper pipes, then using a flat file, to file a bright area to solder wires to the copper tubes.
I dread stripping 63 short wires. 126 ends to do, lol
This is going to take some days I think.
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
IotaYodi
@Electricme.
A battery or power drill with a wire brush will save you loads of time instead of using a file. Thats a lot of filing!!  :o
What I know I know!
Its what I don't know that's a problem!
electricme
@IotaYodi
Thats right, silly me has a brand new wire brush in a blister pkt, just clean forgot I had it, its hanging up on the kitchen wall cabinet lol, never mind, I used the fine grit grinding wheel to deburr the 63 copper pipes.
I bought it to derust those huge big iron rings I found over a year ago, I still want to make the worlds largest joule thief with them.
Back to making EB stuff.
I took it easy, no seance in rushing, had a couple of meters of multi core cable, and stripped this back and cut myself 63 X 6" lengths.
I have just finshed sweatting the leads onto each pipe with a 80watt soldering iron, Its amazing how much heat copper can soak up.
0387.jpg = Half way soldering leads to each pipe end (one end only)
0388.jpg = All done, all wires soldered to each copper pipe.
Next step, grab my insulation tape and wind a layer or two from top to bottom, then fold or cover the bottom of each tube end, then grab a handful of Galvenised nails (Zinc) and solder each free end to the top of each nail.
jim
electricme
@All,
I have been waiting for a phone call so I decided to go out back and solder the Zinc nails to the ends of the wires, the nails managed to hold out to the exact number I needed, phew.
I'm outta step with myself, I was going to wrap insulation tape around the outside of each of the copper pipes, clean forgot.  ::)
Well, that will just have to be the next step.
1338.jpg = weatherman a couple of weeks ago said this lot was fish scales, lol, proves he has no idea whats under his very nose doesn't it. :D
jim
Pirate88179
Jim:
Wow man that is a lot of work you are doing down there.  Whatever you do, do not attempt to take those pipes on an airline in your suitcase, ha ha.  The guy x-raying the baggage would have a heart attack.
Nice "natural" cloud formations you have over there.  We have similar ones here too.
Bill
