Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
Pirate88179
Cosmicfarmer:
This is good!!  That is exactly what I have been trying to get other folks to do..those alignment "instructions" are to be adjusted to a specific area, but it is a great place to start.
Back in the old EB topic, this is what Localjoe and I did except we were using very small electrodes at the time.  We sank one in the ground and metered the other one for distance and n/s alignment...we took our best readings and...there we put them. (this was before I knew about the depth making a difference as well)  Later, I found that i was aligned almost perfectly with the n/s meridian.  Anyway, I like how you manually tested and found your alignment, distance and depth.  Bravo.
1.480 is not a bad beginning output voltage at all, very good actually.  You watch, it will get better in a few days, and then even a few weeks later my guess is that it will be much closer to 2 volts range.  Your power will increase as well, if it is like my experience.  I used mine, then let it sit a few days, and used it some more and let it sit while I was working and...everything went up which is consistent with reports from Nathan Stubblefield himself.  You have plenty now to light an led using a simple JT and one supercap.  Later, you will have more.
Very good results here, keep up your experiments.
Bill
electricme
@Cosmicfarmer and Pirate,
wow, it's getting interresting again, more things with earth energy to do.
First off, I don't have a truck to haul a dish back home, and the install mob hasn't told me when they are going to arrive her.
Just got a email from GetUp in Australia, seems the gov here was going to try and sneek through the ISP control, or internet censorship over christmas while everyone was thinking about other things like NWO climate change rubbish.
Be aware people, the NWO is trying to close all the open doors, very soon australia Internet is going to be like Chinas Internet, lets hope Stefan has this under control.
Bill, If OU is banned from this neck of the woods, then I will keep in touch via you about whats hapenning with EEB and the JT, going to get skype asap.
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
freepow
 :) Hello All, I'm back at last !
I need to get serious about free energy from the earth, coz the electricity bill has recently gone up
by 30%, It used to cost us every 3 months around $180-200 Aust, but now its up another 30%, and over the next 3 years its going up another 60-70%, all because of this stupid carbon tax rubbish and climate change, I know there's no such thing as climate change, their fooling with the weather, Nicola Tesla knew all about it, and they have HAARP and not to mention the local smaller ones around the world, if no one believes me, well thats their opinion, but I know its true that they can and do make droughts,floods,etc.
Pirate88179
Freepow:
I agree with you.  There is enough evidence out there now to prove this climate change deal is all a scam.  It still does not stop our bills from going up though.  Together, we will find a way for free energy for all.
Bill
Cosmicfarmer
2 volts? How about 4 feet?
My back yard is sunk in 4 feet of snow
and I think I will let it entrain over that alligator clip... which is being protected by some stationary water.
When I add or remove parts to this, I always hook my new part in parallel, then I remove the short.  Possibly if I have patience, allow a day between each step, add or remove.
But I am noticing alot of wear on both trodes... carbon looks ok but magnesium lost its lovely shine.
I'm thinking instead of buying I should bake a log and bury that longwise in the earth, and then find something metal or bury a pipe .  Imagine a whole neighborhood based on burnt lumber and tuned plumbing in the earth for their light and power.   Electric Islanders..  Without 60hz.
Got my joule theif working really candy now.  Can get 160 volts from 1 volt or whatever mjl21194 has. Battery swap switch and rechargeable batteries make it a forever hv light, but I can't wait to get a big toroid for christmas ... maybe!
You need light? take a joule theif with a charge battery spot, and make its input the ground battery, then you got ground powered battery stations surrounded by high voltage light LED strings... Mmm fancy.  But can the earth supply the amps?  or do I have to capacitor it...  And speaking of which
Anytime you trade voltage from one cap to another you loose 75% from what I remember, so what ever bucket gets filled with ground power is what is basically going to power the joule theif, and from there what ever.  You are going to need a series / parallel arrangement to get initial volts up from under 1.  You could charge 24  caps to .5 and slap them all together for a moment and you have 12 volts. The trick would be to have a sensor on it and flip the caps when they're hot.
After 100 hours I obtained ~240mv from the ground using bridge rectifier method. I think what I will do next is take out half the diodes and observe correct polarity of grounds.  Plus I now have a better tuned backyard.
I'll get that graph later. so tired from the snow.
