Patents involving antenna and aerials, mainly for transmitting...
Started by the_big_m_in_ok, July 24, 2009, 09:37:48 PM
the_big_m_in_ok
#1,869,192
Large, hanging system having mid-span capacitors
http://www.google.com/patents?id=Py1bAAAAEBAJ&pg=PA1&dq=patent:1869192&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#1,813,143
Looks like a pole-mounted electrical square wave using wires
http://www.google.com/patents/about?id=OXFKAAAAEBAJ&dq=patent:1813143
#1,743,124
Tuning system based on air core transformers
http://www.google.com/patents?id=kQFGAAAAEBAJ&pg=PA1&dq=patent:1743124&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,739,941
90 deg offset coils + a sheet antenna arrangement similar to Lakhovsky.
http://www.google.com/patents/about?id=mm8_AAAAEBAJ&dq=patent:1739941
#1,724,246
Unusual, pyramid-shaped intermediary shaped structure with 5 air core coils and a vacuum tube tuner(which you might? disregard?)
http://www.google.com/patents?id=JSlFAAAAEBAJ&pg=PA1&dq=patent:1724246&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#1,224,499
Sliding, counterwound coils that can also have an additional step-down coil with 1-2 turns.  Radiotelegraphy or radiotelephony
http://www.google.com/patents?id=qEZjAAAAEBAJ&pg=PA1&dq=patent:1224499&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#1,184,376
Similar to the one immediately above
http://www.google.com/patents?id=P21cAAAAEBAJ&pg=PA1&dq=patent:1184376&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#1,127,921
Multi-tap coil tuner
http://www.google.com/patents?id=a5FXAAAAEBAJ&pg=PA1&dq=patent:1127921&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#1,101,914
Fig. 7 has a spiderweb construction scheme
http://www.google.com/patents?id=z1NHAAAAEBAJ&pg=PA1&dq=patent:1101914&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,082,221
Rather like Marconi's work, but has an additional air core transformer to the receiver
http://www.google.com/patents?id=19NIAAAAEBAJ&pg=PA1&dq=patent:1082221&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
Additional reminder to newbies and the curious public:
These are generally patents for transmitters.  Enlarging the size, pulling up the end of a grounded loop and adding a tuning capacitor may give you new ideas for inventions of your own.
--Lee
the_big_m_in_ok
#1,373,612
Underground air core loop antenna
http://www.google.com/patents?id=p_5aAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,322,622
Finally. The same inventor immediately below does away with the conduits and merely has buried, radiating wires(in the same vein as HAARP) for a tramsmitter.  (Figs. 4 & 5)
http://www.google.com/patents?id=UeJAAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,315,862
Uses buried square wound coils on a cross beam form like an Iron Cross.  This system might settle the question whether or not 50-60 Hz ambient emanations are what most people pick up with atmosphereic antenna suystems
http://www.google.com/patents?id=iN9cAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,303,730
About the same as #1,220,005, by the same inventor, using what amounts to a co-ax cable instead of a conduit
http://www.google.com/patents?id=cwRAAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,303,729
An old submarine system that uses forward and aft dipole wires to an air core transformer
http://www.google.com/patents?id=cgRAAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=wireless&f=false
#1,220,005
Wireless transceiver using buried wires in a conduit.  The inventor claims it works, I suppose.  Without aerial transmission through the atmosphere?  Go figure.
http://www.google.com/patents?id=C4RXAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
Re. 26,196
The first Reissue.  An open ring system that has Fig. 4 on a large scale
http://www.google.com/patents?id=1t8XAAAAEBAJ&pg=PA1&dq=wireless&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=b&as_minm_is=1&as_miny_is=1850&as_maxm_is=1&as_maxy_is=1921&num=100&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
the_big_m_in_ok
#1,640,534
Pole mounted system that uses 2 ea. paralleled wires to multi-tap air core transformer
http://www.google.com/patents/about?id=44l5AAAAEBAJ&dq=patent:1640534&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=
#1,481,585
Rather similar to #847,008.  Effectively, a wire is counterwound into a tape like somewhat like a Mobius coil
http://www.google.com/patents?id=FLBGAAAAEBAJ&pg=PA1&dq=patent:433702&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,101,175
Large, pole mounted system as a siderweb coil, plus paralleled wires(Fig. 3)
http://www.google.com/patents?id=HrlFAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#984,762
Tuning coils with vaiable caps
http://www.google.com/patents?id=_2BeAAAAEBAJ&pg=PA1&dq=patent:984762&num=100&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#978,607
Protecting motors, using capacitors and a spark gap to an antenna
http://www.google.com/patents?id=1yhPAAAAEBAJ&pg=PA1&dq=patent:978607&num=100&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#978,606
#3 on the drawing is a multi-tapped toroid
http://www.google.com/patents?id=oWN-AAAAEBAJ&pg=PA1&dq=patent:917103&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#928,371
3 counter-wound coils, 2 of the paralleled (Fig. 3)
http://www.google.com/patents?id=73NAAAAAEBAJ&pg=PA1&dq=patent:928371&num=100&source=gbs_selected_pages&cad=1#v=onepage&q=&f=false
#917,103
http://www.google.com/patents/about?id=oWN-AAAAEBAJ&dq=patent:917103&num=100
#847,008
This is a good one.  The inventor replaces a transformer core with wire overlaid with more wire in a coil that transmits telephone conversations with fidelity.
#619,760
This was originally designed as an electrical converting "apparatus".  Has 3 counter-wound coils
http://www.google.com/patents?id=OugsAAAAEBAJ&pg=PA1&dq=patent:433702&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
--Lee
the_big_m_in_ok
#7,053,576
The first system that's not necessarily an antenna:  Fig. 14 has 2 tesla coils that charge a battery through 2 tubes that look like Gray's special tubes in his patent elsewhere on Overunity.com
http://www.google.com/patents/about?id=4Nh3AAAAEBAJ&dq=patent:7053576
#6,974,110
Grandic's famous pyramid system that charges a capacitor from a coil set on top of a pyramid
http://www.google.com/patents/about?id=tncUAAAAEBAJ&dq=patent:6974110
#4,628,299
Tate's seismic warning patent using ambient energy
http://www.google.com/patents?id=ucg9AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
Also, on overunity.com:
http://overunity.com/index.php?topic=3961.0
#4,262,256
Power extraction system from overhead high tension (mains) wires
http://www.google.com/patents/about?id=z5w7AAAAEBAJ&dq=patent:4262256&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=
#911,260
A balloon system sinilar to Plauson's
http://www.google.com/patents?id=KVZLAAAAEBAJ&pg=PA14&dq=atmospheric+electricity+collector&source=gbs_selected_pages&cad=2#v=onepage&q=atmospheric%20electricity%20collector&f=false
More later, if I have the time...
--Lee
the_big_m_in_ok
Second index list, in numerical order, for reference:
#7,053,576
#6,974,110
#6,463,875
#6,147,655
#5,914,692
#5,841,407
#5,835,066
#5,805,114
#5,734,353
#5,404,117
#5,159,332
#5,065,099
#4,922,261
#4,804,965
#4,701,764
#4,633,250
#4,628,299
#4,622,558
#4,473,163
#4,407,000
#4,396,920
#4,262,560
#4,028,704
#3,931,577
#3,721,989
#3,716,861
#3,568,205
#3,534,372
#3,530,430
#3,495,264
#3,267,476
#2,957,103
#2,955,223
#2,856,605
#2,813,242
#2,584,314
#2,581,348
#2,537,191
#2,510,162
#2,503,010
#2,373,206
#2,153,975
#2,145,024
#2,143,437
#2,135,234
#2,066,690
#1,869,192
#1,813,143
#1,743,124
#1,740,851
#1,739,941
#1,724,246
#1,640,534
#1,602,085
#1,575,824
#1,538,466
#1,504,303
#1,481,585
#1,373,612
#1,350,100
#1,322,622
#1,315,862
#1,303,730
#1,303,729
#1,224,499
#1,220,005
#1,184,376
#1,127,921
#1,101,914
#1,101,533
#1,101,175
#1,081,221
#1,014,719
#984,762
#978,607
#978,606
#928,371
#917,103
#911,260
#847,008
#795,762
#674,427
#619,760
#287,973
RE26,196
--Lee
