Patents involving antenna and aerials, mainly for transmitting...
Started by the_big_m_in_ok, July 24, 2009, 09:37:48 PM
the_big_m_in_ok
Quote from: forest on September 29, 2009, 02:39:15 PM
# 7,053,576
http://www.google.com/patents?id=4Nh3AAAAEBAJ&printsec=abstract&zoom=4&source=gbs_overview_r&cad=0#v=onepage&q=&f=false
Very good, forest.  This that one above I had forgotten about, but I did say in my description elsewhere on this thread, one of the figures in the patent has an embodiment dealing with charging batteries from the Tesla coil(s).
Also, Edwin Gray was granted a patent for a system that used a certain type of rather capacitively induced wire-and-cylinder coupled component.  Rexresearch.com may have a reference.
RE-EDIT:
Here you go:
http://rexresearch.com/evgray/1gray.htm
Gray's motor and power supply.
--Lee
the_big_m_in_ok
#5,625,371
A TV antenna that can fit on the back of the set.  Can be expanded:
http://www.google.com/patents?id=5ptUAAAAEBAJ&pg=PA1&dq=antenna+loop+RF&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#4,801,944
Similar to #2,657,312.  For a radio, that can be anlarged:
http://www.google.com/patents?id=KAw4AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#4,051,479
This one can be mounted on a pole, for less efficiency:
http://www.google.com/patents?id=mlITAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#3,259,901
Should be mounted on a much longer pole(Fig. 2):
http://www.google.com/patents?id=xYhpAAAAEBAJ&pg=PA1&dq=patent:4801944&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#3,215,937
An ELF, HAARP system for very large applications:
http://www.google.com/patents?id=6R1ZAAAAEBAJ&pg=PA1&dq=patent:4801944&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#2,657,312
This system can be enlarged greatly(Fig. 4).  A circular set of interspaced arcs:
http://www.google.com/patents?id=yRFzAAAAEBAJ&pg=PA1&dq=antenna+loop+RF&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#2,469,209
A single-ended system to a coax, with a three-dimensional closed circle:
#1,899,410
Zigzag, 3-dimensional, triangular system---pole mountable, with tuning coils:
http://www.google.com/patents?id=ArJOAAAAEBAJ&pg=PA1&dq=patent:4801944&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,429,240
This one is related to Earth Batteries.  The question is, will adding a long wire, either above or below ground, affect performance?
http://www.google.com/patents?id=-q5TAAAAEBAJ&pg=PA1&dq=patent:4801944&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,424,365
This one is above and below ground.  Generally for radiotelegraphy:
http://www.google.com/patents?id=2t1HAAAAEBAJ&pg=PA1&dq=patent:4801944&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
--Lee
the_big_m_in_ok
#4,954,790
Fig. 3 might be okay for an all-coax system on a large scale:
http://www.google.com/patents?id=0ywcAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#3,731,237
Specially wound toroids:
http://www.google.com/patents?id=goY6AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#1,540,998
Plauson's famous atmospheric energy conversion patent + more information:
http://www.rexresearch.com/plauson/plauson.htm
(Would not load and run on  http://google.com/advanced_patent_search ).
Try this:
http://www.pat2pdf.org/patents/pat1540998.pdf
NOTE:
Please be aware, 2.21 MB file, 28pp.
And, it ran from the 'preview' screen on the computer I'm borrowing.
--Lee
the_big_m_in_ok
#5,939,238
I wonder what effect this thing would have on a Joule Thief?
http://www.google.com/patents?id=XbYYAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#3,428,886
Both Figs. 5A & 5B plus the 'prior art' Figs. might be usable in a Joule Thief:
http://www.google.com/patents?id=NIdgAAAAEBAJ&pg=PP1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
NOTE:
The number on this patent 'Web address doesn't match the patent number.  Same thing with every one below to the end.  That's the way it copied from the web browser.  I don't know why.  They give different patents when I click on them, though.
Also, 'Web addresses probably won't work if any part of it's in bold letters.  I tried with this address.
#3,305,800
Dual toroid sets in series/parallel configuration.  Try this in a Joule Thief?
http://www.google.com/patents?id=ifxxAAAAEBAJ&pg=PA2&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#3,114,120
Twisted wire transformer with one coil---filtering or impedance matching, mostly:
http://www.google.com/patents?id=_VpHAAAAEBAJ&pg=PA1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#3,066,236
Unusual toroid wound on a bolt washer:
http://www.google.com/patents?id=U7ViAAAAEBAJ&pg=PA1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,133,750
Both a toroid and a Caduceus coil:
http://www.google.com/patents?id=x_BmAAAAEBAJ&pg=PP1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
--Lee
