Patents involving antenna and aerials, mainly for transmitting...
Started by the_big_m_in_ok, July 24, 2009, 09:37:48 PM
the_big_m_in_ok
the_big_m_in_ok
the_big_m_in_ok
forest
Which one patent uses plasma tube as a part of antennae ? I heard that it's possible to extract electrical energy from plasma (vide Correa patents) Did you find more patents using plasma ?
the_big_m_in_ok
Quote from: forest on September 29, 2009, 03:45:21 AM
Which one patent uses plasma tube as a part of antennae? I heard that it's possible to extract electrical energy from plasma (vide Correa patents) Did you find more patents using plasma ?
I hadn't found any like that yet.  I was only looking for wire antennae for this particular forum.
I did find several that used radiation to generated electricity, though.  (Patent #4,835,433 is one example; there are others).  I might start a thread in the Half Baked Ideas Forum  concerning this.
But, if I do find one, I'll reply to your specific post with a quote, the number, and the GOOGLE patent address.
RE-EDIT:
Here's one possible right now that I stumbled on:
#4,303,845 at   http://www.google.com/advanced_patent_search
It's not just not *exactly* plasma electricity generation, but it's fairly close.  If I find others, I can copy them here.
#6,164,241
Here's one that generates plasma, but Fig. 5 can be used to conduct electricity to the capacitors in the drawing:
http://www.google.com/patents?id=c_oEAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#4,844,775
This is a commercial vapor deposition/etching process that requires electrons be removed from a plasma the then the ions are accelerated to the target:
http://www.google.com/patents?id=-ug0AAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
Please keep in mind:
Many of these patents are designed to generate plasma, not extract electrons from it.  High density plasma can melt the coils in a hurry.
Furthermore,
MHD and MPD systems are often designed to generate electric power from plasma mixtures that are confined by magnet/electromagnetic fields.  There are more than enough patents to this effect to be search for.
--Lee
