Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
bw
I have built two Don Smith devices.  I get readings of volts and amps on meter with one device (plasma globe), the other I got nothing but I didn't follow all Don's specs(dipole generator).  I know very little about electronics but feel Don's devices can be very powerful.  I remember him saying the more rapid the spark gets the closer the load matches the generator.  Or maybe Tesla said that.  He invented and patented a similar device with huge outputs.  Anyway someone on this form was discussing the time between spark discharges changing on their unit.  Hope this helps.
I also remember Don talking a lot about photomultipliers so I googled it and after a little research this thing sure looks a lot like overunity.  They multiply one electron into 100 million electrons using only small power supply, they're used in night vision devices, old automatic headlight dimmers among others.  I bought Don's dvd and on it he describes a few devices and shows the camera a close up view of a neon power supply and says to look at the input and output ratings right on the nameplate.  The input watts are lower than the output.  His point was that overunity devices are all around us, we just do not realize it.  I ordered the neon power supply, mine is "NeonPro" and damn if it isn't overunity.  The input is 110v @0.5 amp that should be 60 watts.   The output is stated at 5000v @ I forget the miliamps but it calculated to 150 watts output.  This guy is for real and I just wish I knew more about electronics so I could SAFELY continue.
flathunter
I hope you are right!  I have a 150 W output Neon Sign Transformer in my Tesla Coil, and i'd love to find out it is already an OU machine!!!!
It would certainly save me a lot of bother!
onthecuttingedge2005
Here is what BW was referring to.
I am working on solutions for just this cause but a little more complex than this using specialized crystals, Light trapping Crystals, Light Amplification Crystals, Photovoltaic Crystals all in one layering to greatly amplify Photons for the production of electricity produced in the Photo chain reactions with the LASED Crystals.
the dynodes below are electroplated with Gallium Arsenide.
Jerry ;)
xenomorphlabs
Quote from: Peterae on August 28, 2009, 11:25:22 AM
xeno
Can i ask how you got the value and rating of the secondary cap, as it is still not clear enough to read in the best picture we have.
The reason i ask is that all the caps i have been looking at for 0.5uf 8kv are massive.
Cheers,
Peter
Peter,
i have a 10kV cap here that is is rated 10nF that looks exactly the same size-wise like the one in Smith`s device. So you are absolutely right that
a 0.5 uF one would be much bigger.
I will look through the tons of data i have collected about Smith to find that quote and let you know if i should find it.
@bw: Great to hear that you already attempted to replicate a Smith Device !
Your input is well appreciated here as well as anyone`s constructive input so we can realize a working replication :)
Smith also states something peculiar about the dimmer on his Neon Tube Transformer, that if he reduces the voltage for the transformer with the dimmer the amperage in his whole device can go up more than the device can handle, so that is melts ?! Very interesting hehe.
I have ordered myself a 9kV 30mA NST with a dimmer on it. Let`s see if i can melt stuff with it :D
Peterae
Hi xeno
Thanks for looking this up for me, i have seen a 0.05 10kv which may well fit the size we are looking at.
Almost finished gluing my first secondary together, i think the size is too big, i ended up 3.25 inches diameter DOH
Total Length 11.25 Inches with a 3 turn gap between each 20 turns.
I used 14swg wire for the coils, but think this is too thick compared to your photo's so i will make another secondary and try to aim for 3 inch outer coil dia using 16swg wire.
Dip meter showed res at 3.51Mhz using a 100pf cap for the 20 turn coil, I couldn't determine how accurate the cap was as i have 2 meters and each meter read differently.
To me the dimmer looks seperate in the clear photo and is on the end of the radioshack 12vdc to 125vac inverter , not sure if the bertonee transformer also had a dimmer built in, i have found very little info on this original transformer.
Shouldn't be too long before i'm also melting things  ;D
Peter
