New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
wattsup
@winsonali
Regarding the drawing you show above of the winding which is simple bifilar, may I suggest instead 3 to 4 bifilars twisted 6-10 turns per inch then wound.
During passage through a coil, you have magnet to iron core relation but you also have magnet to energized coil relation as load is increased. The above will reduce the out bound coil field hence the magnet to coil relation and increase amperage output.
winsonali
wattsup:
the setup of the mechanical generation is100 %working unit and a very efficient one i develop this for third world countries where they need fan attaching this kind of generator with fan will give power to run other appliances getting extra power lower cost and they need air through fan in any way
about coil i don't know about bifilar but i did it to produce equal and opposite mag field when coil consume current.
whatever will come up now for energy solution is not that easy it is very complex as you know i was working on DC input for genie i have completed that section. and also load balancing in the final stage.
there are more sensors and quite complex switching....
now coming to multiple stages i have not given 2nd though about that i am working on unified PCB and its smt layout and planning for final design once i will complete that work then i will think about these things.
EMdevices
Ali,
do you know why you don't have a closed loop running system, because they are not possible, given your configuration,  it would be perpetual motion, an impossibility.
On the other side, if you found a source of free energy, then you would understand it, but I don't see it from you.  A bunch of pulses imitating a sign wave is not free energy.
don't deceive yourself,  because I'm not.
I appreciate your sharing and exploring, but please don't make claims you can't substantiate.  Words are cheap on this forum.
EM
aaron5120
Quote from: winsonali on December 22, 2009, 05:50:10 AM
aaron
here is more information and why this setup is better then conventional methods also i have mentioned how to wind the coil in this way it will reduce magnetic resistance and give you smooth output
also i have mention the MOSFET on / off times for load collection
Many thanks for this information, WinsonAli. They are very important for me in order to replicate the Mechanical Generator.
One last thing I want to consult is the shape of the external magnet (See the attachment), is it a ring magnet, with a perforated hole in the centre, or is it a cup magnet that masks the whole shield and inner magnet? And which is the material used for it, ceramic or NeFeB? If it is a NeFeB, a grade 40 will do? How thick the external magnet should be in order to accomplish the compression job?
Thanks for your help, Ali. And congratulations for achieving self-running of your Solid State Genie! ;)
Aaron5120
winsonali
EM devices:
i can understand your point of view as i can see your posts on TPU many years of work but no results
any way for me your are very respected and have very good knowledge. i have developed some thing different you will see soon... a small story
In a village there was no rain for long time all wise and elderly man decided to pray for blessing of GOD and gathered next  morning in a ground all wise and elderly man came bare handed only one young boy came with an umberalla and rain coat.....
Lesson to learn.....  only the young boy have believe in what he was......
may be i am the young boy believing in my hard work
arron:
the attached picture will help you you don't need 2 magnets the arrangement you provide sheilding and central magnet..
more power full magnets means more current......
