New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
hello all
there are many people working on magnets
is there any simple low cost method  to calculate the power of magnet?
wattsup
I think @winsonali covered much of his device intricacies to realize that his device encompasses some pretty complex circuitry and function that goes above and beyond the capability of many here to take advantage of for home OU projects.
Some devices rely on motive movement, others on the recirculating spin (TPU) while devices like his I would classify as a "Peak Wave Harvester".
When you look at a regular pulse wave form, you start at zero, go to maximum, then go back down to zero. If you do this 3600 times per minute, you are in the motive range. If you do this 200,000 times per second, you are getting very fast pulses, but you are still working with the zero to maximum to zero sweeping. So you still have 80% to 95% of the total wave form that is far below the maximum point. So now, if you do this in the giga range and manage to disregard the up and down slopes and only harvest the peaks, that is something very interesting indeed and this is definitely a new way of collecting power as long as what is cut or disregarded can be stored elsewhere and re-used to increase the overall efficiency. Electronic power factor controllers are a few steps away from this since they encompass the wave cutting ability but only in the motive frequency range and only based on meeting the applied load. @winsonali has taken this to the next level which is great and very encouraging.
So I don't see why anyone here should spend his time trying to push the guy. He already confirmed that the technology is saved in good places and he seems to know what he is doing. He does not show any signs of the "I am God" syndrome, a rare attribute indeed, nor does he show any signs of being surrounded by greedy or ignorant people. So all in all I really think he has a good handle on the situation and he takes a level headed approach combined with a fantastic work ethic. I would have total confidence in his ability to both further his tech and also know when it is the right time to release it. Yes, yes the sooner the better is always the first hope, but, I personally would rather he take the time he needs to make it right and all we can do here is offer the support, the encouragement and the knowledge that he has people here he can rely on should he require it. We cannot do more than this at this stage. Again, having such a complex device would make it very difficult and confusing for a real open source development. So I would say to @winsonali, keep on truck'in and know that there are guys here to cover your back should you need it.
wattsup
@winsonali
I just posted the above a few minutes after your question so I did not see it.
You may want to expand on your question since you can measure field strength from the mag field itself versus distance from the magnet or from the holding capacity of the magnet. There are many ways to do it without actually requiring the real field strength in Tesla, but as a point of comparison to other magnets or coil fields.
I remember @otto had measured the field of his ECD unit a good while ago but can't remember the device he made to do it. But he was able to plot out the field I think up to 6 feet above his unit with his device.
teslaalset
Quote from: winsonali on December 26, 2009, 12:37:56 PM
hello all
Ali, merry Christmas.
If you mean force, you might try the program Femm to simulate forces. It can give a pretty good indications.
I am pretty familiar with Femm, so if you need some help with it, let us know.
p.s. it's freeware, simulating in pseudo 3D (2D + indicated depth of the setup)
winsonali
wattsup and teslaalset
wish you and your family happy year and Merry Christmas
wattsup thank you for your understanding
you are 100% right when a sine wave starts from zero almost up to 20% you get very low power and vice versa so its really an understanding when to take load in consideration, until and unless you are not analyzing wave form in you r circuit you cannot do this
just think can you make a harddisk in your home like wise this is a fairly complex system but you do understand how the system is working
once system is available everybody will enjoy and we will get low entropy and carbon emissions.
